Results 1 to 8 of 8
Thread: Is there a native LW equivalent for.....
    Is there a native LW equivalent for the db&w tools "Rotate" node? It's part of the Variables group in that toolset.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    7,950
    ...as usual in such situations...
    ..if there would be equivalent of [whatever]..
    there would be no need or sense or economical sense, making 3rd party tool doing the same...
    Well yah that makes sense, but the db&w website says this about the Variable collection of the tools "Variables - Variables (Angle, Colour, Distance, Percentage, Position, Rotation, Scalar, Scale)
    a collection of nodes similar to the native constant nodes, but with the option to motion blur the evaluation of their envelopes or even drive the time of evaluation directly". So if I go to the Constant nodes in LW I don't see a rotation equivalent. I'm not interested in any motion blur.
    Tim Parsons
    Technical Designer
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,540
    Translation, Scale, Rotation are all vectors; The first two are <X,Y,Z>, and rotation is <H,P,B>. Unknown whether rotation is in degrees or radians, though...
    My Scripts for Lightwave
    If I search the node tree for Rotation nothing comes up. If I search for Rotate I get a Deform:Rotate.
    Tim Parsons
    Technical Designer
    Feb 2009
    Prescott, IA
    1,540
    Use a vector node under constant. Heading into the X channel, Pitch into the Y channel, and Bank into the Z channel.
    May 2006
    France
    4,102
    If you want just a HPB constant vector,
    note that in node editors angles are in radian (360° = 2PI rd)
    you need 3 Angle constant nodes for each Axis,
    this will convert your 3 degrees angles in 3 radians angles,
    then plug them in a Make Vector node.
    Denis.
    Sep 2015
    Sweden
    652
    What are you trying to do? Is it acceptable to use a null and get the rotation from that using item info?
