Results 1 to 12 of 12
Thread: Modeler Tool equivalent to "contract" or "expand"?
    I've run into this situation occasionally and have always ended up finding a workaround. But what I'm really looking for is a tool within Modeler that is comparable to Photoshops "Expand" or "Contract" function. I want to shrink (or grow) an object within it's own parameters. For simple objects like a cube or sphere, obviously you can simply resize it. But for unusual shapes (see attached image) resizing it means it no longer conforms to it's previous 'outline'.
    ...This is really hard to describe with words. Hopefully the attached image clearly demonstrates what I mean though. Is there any tool (or method) in modeler that would achieve this result?
Name:	Contract Tool?.jpg
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,519
    Bevel or multishift can expand or contract a flat polygon(s) easily, just use the inset value to achieve your effect.
    My Scripts for Lightwave
    Frequenter
    Munich
    352
    Wouldnīt thicken work nicely for this? Expand or contract (apply new surface names in the numeric panel accordingly while you are at it) and then just selecting the respective surface parts and cut the unwanted portions?
    Point Normal Move might be effective.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Virginia
    2,955
    Smooth Scale
    1,433
    Quote Originally Posted by SilverFalcon View Post
    Since no one has mentioned the obvious, there are several modes you can use with the Size tool (+H). Have you tried the Selection or Pivot options?
    Jan 2011
    Seattle
    376
    If you are trying to bevel evenly, try multishift, and try the different modes in the "inset" dropdown, in the numeric panel, to find the one that works best.
    3D objects can be expanded via smoth shift (play with the smoothing angle to get the result you want
    for sinle polygons its either multishift or bevel, or... extruding your 2d shape and use smooth shift.
    (also some other tools mentionend in posts above only work with 3d shapes)
    hope this helps
    Thanks everyone.
    Multishift and Bevel don't work in the way I want for this function since they work on each polygon individually by default. And size tool, regardless of tool center (origin, selection...) doesn't work for this since I'm not after a uniform size change, but rather an inset or expansion of the object. I'm sure tweaking the settings in Multishift could eventually get me the effect I'm looking for, but it's not the 1-click answer I was after.
    Smooth Scale is exactly what I was looking for, Thank Chris
    Thicken also works great as a way to do the same function while creating a new object (preserving the original).
    Appreciate the responses, thanks!
    Feb 2009
    Prescott, IA
    1,519
    With Multishift, be sure to check the box marked "group polygons". Treats the entire selection as one polygon, then.
    Virginia
    2,955
    Smooth Scale is exactly what I was looking for, Thanks Chris
    Sure. Glad to be of service.
    Mar 2018
    Perth, Australia
    82
    I agree.... use Multishift.... WAAAAAAAAAAAAAAY more control over what you need to do. As Kryslin says, tick 'group polygons' and make sure you have Contour selected as the insert operator.
    Most important thing of Multishift is that it is interactive... you can actually see what you are doing and what different settings do.
