Thread: Add OpenVDB in LW SDK programming to support Third pary 3D Rendering
    Apr 2015
    France
    150
    Not sure but I would like to see for adding OpenVDB in LW SDK to program and to support for external 3D Rendering that would be speed up to access and to export great gases and liquids
    15,118
    well..yes ..why not.
    I just had a go at the disney vdb cloud asset
    ..and even with the half sized dataset..it renders too darn slow...at least compared to the primitive volume type, and it's a pain to tweak scattering and other channels.
    May 2006
    France
    4,042
    As a primitive, I suppose you can evaluate it with LWPrimitive,
    with the Item ID you get the LWPrimitiveEvaluatorID,
    its flag says if it is solid or gaz, then you have several volume functions,
    for ray marching through,
    I suppose also that bounds is what you need first for the renderer.
    Or knowing that OPenVDB is open source,
    make your own with a LWPrimitive handler.
    Denis.
    Apr 2015
    France
    150
    I see what you mean Denis, thank you for more info and I will do what i can make to my renderer
