Page 1 of 9 123 ... LastLast
Results 1 to 15 of 128
Thread: intel vs AMD - Benchmark 2019
    alright, you guessed it, a new benchmark scene
    post your machine specs, overclock or regular, render time
    here is mine >
    Render time = 24 minutes 47 seconds
    Intel Core i5 Quad 760 8MB Socket-1156 2.8GHz (not overclocked)
    12 GB DDR3 1333MHz
    1. DO NOT ALTER ANY SETTINGS IN THE SCENE
    2. Do not touch the computer while rendering
    england
    1,359
    here is mine, 7890xe on asus rampage vi extreme running asus turbo at 4.2ghz on all cores, 85.8 seconds (ps incase it makes a difference but hopefully not LW 2019.1.2)
    Cool, that's extreme alright.  
    it is impressive how much that intel is able to overclock. To the edge of Fantastic!  
    Not to bad from the old 1950x
    I'm a Norwegian photographer, check out my web site www.fotofashion.no
    the old 1950x
    Overclocked? if not, would you try it?
    i'd love to see the test if anyone is in possession of an AMD Ryzen 9 3900X  
    Super Member Qexit's Avatar
    Warrington, UK
    1,146
    Here's my attempt.
    Render Time: 10m 34s
    PC specs:
    Dell Precision 5810
    LW 2019.1.3
    Windows 10 Pro Version 1903 build 18362.356
    Xeon E5-1620 v3 @ 3.5GHz
    16GB DDR4 ECC 2133 MHz
    GPU 8GB Quadro M4000
    Kevin F Stubbs
    yep, pretty much the rendertime i had expected.
    sometimes i use this Cinebench r15 to compare,
    https://www.cpu-monkey.com/en/cpu_be...5_multi_core-8
    not a 100% accurate guide, but somewhat close.
    low + mid range AMD computers seem Great versus price, the top range AMDs, a bit less.
    Guesstimate >
    for example, 7980xe will give you about 1 min render time and cost Lots of money
    and AMD Ryzen 3900X with a cheaper motherboard + CPU will cost much less than half and render in 2 minutes.
    however, you would then have to build TWO computers to make the 2 AMDs render in 1 minute.... so... well...
    Registered User jaf's Avatar
    Oct 2006
    San Diego, CA
    495
    Thee old Ryzen did it in 4m 19s.
    13Jan2020: Lightwave 2019.1.4 Build 3133, win10 pro 1909 build 535, AMD Ryzen 1800+, 64 GB mem, EVGA GeForce GTX 1080 ti v441.81 (13Jan2020)
    Rough estimate,
    4x Ryzen 1700 (overclocked) machines will give you 6500 Cinebench r15 points
    at less than half the price of an 7980xe.
    but is it still worth it ?...
    i'd say yes, and no.
    it depends. if you need a huge render farm, then cool. if you don't, then perhaps not so much.
    p.s. this thread is linked over at LightWiki
    https://www.facebook.com/groups/ligh...18016904970964
    thanks Kevin   
    Cinebench is actually kinda worthless as a metric once you go into the high end. Some of the high core count xeons finish it in less than 10 seconds, not even giving it time for thermal throttle to come into account.
    could be, from what i've seen though it mostly holds up.
    so hope more people chime in with results.
    Here is my results:
    LW2019.1.3 - [email protected] 64GB DDR4 @ 3066 Mhz. Windows 10 1903
    england
    1,359
    Quote Originally Posted by Lito View Post
    Here is my results:
    consistent with fotofashion not a bad score, starting to think they broke a lot in newer PCs as older ones seem to be holding out better (even in the 9980 there have been issues)
    Nov 2018
    Germany
    44
    TR [email protected] 3,8Ghz
    When you do the math and factor in clock speed and core differences there isnt really much of a difference between AMD and Intel.
    Very interested to see a 3000 Series CPU running this one.
