Thread: NDI 4.0 Scan Converter -> VMC1
    Apr 2018
    London
    21
    Has anyone tried running Scan Converter from NDI 4.0 Tools and viewing the feed on a VMC? On both of our VMC's it is incredibly laggy. If I view in Studio Monitor on a PC it looks completely fine.
    Michael Valentine
    Global Head of Broadcast Technology @ Gfinity
    I've been using this combo for quite a while without issues. However, I have been running beta software on the VMC, but even on my other systems running NDI 3.8 level code, I've not seen a problem.
    Is your VMC1 up to date on software? While we don't make a big deal on this, you can update Ethernet drivers on the system, the new drivers can improve the performance of the 10GbE interface some, it might be worth a try.
    Apr 2018
    London
    21
    I'm going to update the VMC1 software next week hopefully and will report back (I *think* we're a couple behind latest currently but will check). Running Scan Converter from NDI Tools 3.7 there was no issue on the VMC. So at least it our setup, the issue seems limited to NDI Tools 4.0.
    Michael Valentine
    Aug 2015
    london
    233
    Quote Originally Posted by Meekel View Post
    One major change in NDI4 is the introduction of Multi-TCP. If you are seeing significant differences between NDI 3.8 and NDI 4 performance - the biggest change may be the switch to Multi-TCP. Of course this all depends on what protocol is being used between the devices, but you can now 'favour' Multi-TCP in NDI Access, and certainly messing around with those settings may be worth a try.
