Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 94
Thread: LightWave Importer for Unity
    2,484
    cool, thanks chris
    Thank you! Looking forward to trying the new build!
    Hey Hey, I am getting an error on the model now...I uupdated the LW Importer complete and I get this error.
    Assets/camerabooth/objects/camerabooth2.lwo "needs importing using the latest LWO Importer."
    UnityEngine.Debug:LogWarning(Object)
    VirtualEscapes.Common.Importers.LWS.LWScene:valida teAndBuildPrefabs(List`1, Dictionary`2) (at Assets/Lightwave Importer/LWS Importer/Editor/LWScene.cs:226)
    VirtualEscapes.Common.Importers.LWS.LWScene:OnInsp ectorGUI() (at Assets/Lightwave Importer/LWS Importer/Editor/LWScene.cs:156)
    UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
    Quote Originally Posted by GraphXs View Post
    Hi, yeah that's more of a warning than an error - hopefully it's not too serious and just means you need to reimport it all. One problem that LightWave Importer has is that it can't control the order that things are imported into Unity. So if the object file gets imported after the scene file then I think this warning will appear.
    Can you try the following:
    - Clear the Console log window
    - r-click on the camerabooth2.lwo in Unity and select reimport.
    - r-click on the scene file and reimport
    - Select the scene file and press the Create Scene button in the editor inspector.
    The warning should not re-appear in the console. Please let me know how you get on.
    2,484
    Assets\Lightwave Importer\LWS Importer\Editor\LWSceneBuilder.cs(73,147): error CS0433: The type 'ProgressBar' exists in both 'LWOImporterLibrary, Version=1.0.7214.20196, Culture=neutral, PublicKeyToken=null' and 'LWSImporterLibrary, Version=1.0.7214.33710, Culture=neutral, PublicKeyToken=null'
    LWS version 1.12
    LWO version 1.63
    unity 2019.1.4f1
    do you think a bug or problem some place else ?
    2,484
    oh, got a feature request
    be cool to have an option to combine all layers in the LWO to a single mesh in the LWO importer options
    LWS version 1.12
    LWO version 1.63
    unity 2019.1.4f1
    Ah sorry, my mistake. The LWOImporterLibrary contained in LWO Importer is out of date by 15 minutes compared to the one in the full LightWave Importer asset. I'll update straight away.
    Thanks for letting me know
    Yes I agree that would be cool - except I think it will break the LWS Importer when (if) it needs to use an objects individual layers in a scene.
    ...hmmm I'll have to give it some thought to see if there's a way around it.
  9. #24
    2,484
    any thoughts on this one ?
    LWObject.OnEnable must call base.OnEnable to avoid unexpected behaviour.
    UnityEditor.Experimental.AssetImporters.AssetImpor terEditor:OnDisable() (at C:/buildslave/unity/build/Modules/AssetPipelineEditor/ImportSettings/AssetImporterEditor.cs:423)
    Unity 2019.2.8.f1, when you select and LWO in the project view tree in unity.
    got this as well on reimport
    OnInspectorGUI should call serializedObject.Update() at its beginning and serializedObject.ApplyModifiedProperties() before calling ApplyRevertGUI() method.
    UnityEditor.Experimental.AssetImporters.AssetImpor terEditor:ApplyRevertGUI()
    VirtualEscapes.Common.Importers.LWO.LWObject:OnIns pectorGUI() (at Assets/Lightwave Importer/LWO Importer/Code/Editor/LWObject.cs:194)
    UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr) (at C:/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:179)
  10. #25
    hmmm, it looks like Unity have changed something in 2019.2.8 - I'll update mine and fix those bugs. I don't anticipate it taking long (famous last words)
    -Chris
  11. #26
    ok I've submitted a minor update to the Unity Asset store for both LWO Importer and LightWave Importer. The console will stop displaying errors with the new fix.
    My suspicion turned out to be correct: Unity has made a breaking change in 2019.2, however I think you can still use the old version of LightWave/LWO Importer for now until the updates go live. It will still work despite the annoying error messages in the console.
  12. #27
    2,484
    thanks, yeah unity and it’s constant changes, always a bit of a risk to upgrade the unity version.
  13. #28
    2,484
    Still getting that error with latest LWO importer 1.631 in Unity 2019.2.8f1
    Gonna try and roll back project to 2019.2.2f1 and see if still occurs. EDIT -> yep, still get :
    I got the error even though I removed Unity LWS importer. Didn't see an update for that on the store atm. was at 1.12.
    rolled back to Unity 2019.1.4f1. don't want the error, just cos it freaks out other users on project :P
  14. #29
    2,484
    if no UV in object (no texture defined/assigned at all in surfaces) but two surfaces applied to a mesh (set reflection, spec and diffuse settings) using std material. lwo2 format from 2015.3
    throws this warning using latest LWO 1.631 with Unity 2019.1.4f1 :
    LWOImporter generated the following warnings for Object.lwo
    Found 1 instance of unsupported texture mapping. Polygons need to be UV-Mapped to correctly display textures.
    VirtualEscapes.Common.Importers.LWO.LWOImporterLog Manager:OutputToLog()
    VirtualEscapes.Common.Importers.LWO.LWOImporter:On ImportAsset(AssetImportContext) (at Assets/Lightwave Importer/LWO Importer/Code/Editor/LWOImporter.cs:139)
    UnityEditor.Experimental.AssetImporters.ScriptedIm porter:GenerateAssetData(AssetImportContext)
    Didn't happen with one surface assigned and no reflection set with same object.
  15. #30
    Lightwave Importer and LWO Importer are both currently 40% off, as part of the Unity Asset Store Cyber Week Mega Sale!!!
    They have never been this discounted before so, if you haven't already pulled the trigger, now is the perfect time to give yourself an early Christmas present!
