Results 16 to 30 of 41
Thread: Ambient Occlusion?
  1. #16
    May 2006
    France
    4,042
    ...Now is there anyway to adjust the AO node first or globally adjust it?
    For the moment no, I mean in Layout no direct access to node parameters of the node,
    as far I know, there's no command for loading a 'nodes' file,
    not obvious also to retreive its id, for connecting it to node root.
    Thanks,
    Denis.
  2. #17
    May 2006
    France
    4,042
    ...Depends what kind of global adjustment you need for occlusion,
    i.e actually in Amb Occlusion you have the Samples number nodal input,
    if you want to change it we could easily make a constant integer python node
    with a value defined in its script, adding and connecting it in the same batch process.
    Denis.
  3. #18
    May 2006
    France
    4,042
    So here is an example,
    first you need to add the static_integer_node_1 python script as a plugin
    then you can edit the script, go to the line x = 27, change it as you want,
    (edit: of course after a change save the script.)
    launch global_ao_buffer(2), check render.
    global_ao_buffer(2).zip
    Denis.
  4. #19
    Jan 2013
    NA
    86
    Hi, Denis, is there any script to remove all of these nodes?
  5. #20
    May 2006
    France
    4,042
    Quote Originally Posted by mewnow View Post
    No, except reloading the scene, may also be deconnected by deleting the custom buffer.
    Denis.
  6. #21
    Jan 2013
    NA
    86
    I mean I have saved both of the scene and object, but I don't need the custom buffer anymore, I can delete the custom buffer, what about the nodes in all of surfaces? How can I delete them?
  7. #22
    May 2006
    France
    4,042
    Sorry but one by one, because each node is only identified at its addition,
    this is a 'on the fly' workaround, so of course you shouldn't save objects!!
    Denis.
  8. #23
    Jan 2013
    NA
    86
    Thanks for reply.
  9. #24
    May 2006
    France
    4,042
    Ok I wrote another script, remove_global_ao,
    will remove the added nodes, until you don't change surfaces, adding other nodes etc,
    because it works by index, removing the last two nodes in the node editor,
    GlobalAO Buffer needs to be removed manually.
    global_ao_buffer(3).zip
    Added a few readme lines in the script, to resume what I said above.
    Denis.
  10. #25
    Thanks so much Denis! Does it really matter if a node hangs around afterwards. I'm assuming not because I'm sure I have many in node trees that are not hooked up to anything. If deleting the buffer disconnects them - who cares. Right?
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
  11. #26
    Quote Originally Posted by dpont View Post
    Denis.
    Thanks! I'll play.
    Tim Parsons
    Technical Designer
  12. #27
    Jan 2013
    NA
    86
    Thanks, Denis.
    Can LW detect what nodes connect to "GlobalAO" channel? Deleting nodes by connect detection will be more pleasure.
  13. #28
    May 2006
    France
    4,042
    ...Can LW detect what nodes connect to "GlobalAO" channel? Deleting nodes by connect detection will be more pleasure.
    Yes the input, because, then there's a cascade of functions to get each nodeID,
    was just a question of time.
    In this one Remove script destroys the AO node and Integer connected to GlobalAO rout input
    only if they are present, whatever changes you made.
    global_ao_buffer(4).zip
    Denis.
  14. #29
    May 2006
    France
    4,042
    Just a question of visual confusion in the node tree,
    they are never computed, though they are refernced somewhere in memory.
    Denis.
  15. #30
    Jan 2013
    NA
    86
    Thanks, Denis.
