Results 16 to 20 of 20
Thread: Problem with deforming added model parrts on model brought in as an FBX in LW2015.3
    2,038
    Congrats James. Looks like a lot of geometry.
    Only suggestion is try using an HDR environment for lighting id you aren't already. HDR Haven has a really good selection if you're not familiar with that site.
    The Big Apexx System:
    64GB
    Yeah, I'm pushing 16 million + polygons! It takes about 7 minutes to load into LW on my system. [a PC i7 5820k with 32gig Ram, and a 970 Nvidia Card - can't afford the newer cards right now] As mentioned before, this is being done with LW2015.3 as 2019 is too slow for me to work with in my experience. HDR is a possibility though.
    Thanks for the tip of the HDR's. Will look at HDR Haven.
    2,038
    I'm limping along on a nice HP laptop, but it only has a whopping 16Gb of RAM w/ an astounding 4Gb nVideGeForce MX250. I'm down in LA for another month or so & away from my maon system. Kinda forces you to into efficiency, but even that has limits.
    Since I had to do fresh installs, I took my time & got organized this time with the Daz stuff, & figured out what was going on with older content. Don't have Poser installed, but the current Daz understands it fine once put in the proper spots.
    Anyway, used some older assets & started putting together a stress test scene of sorts to see where memory limits were. Got farther than I expected actually so as long as I don't try to do as massive of a scene as you have, I can get quite a ways.
    I can at least get a good start on some ideas.
    64GB
    I'll put up a few more pics of my Centaur City Scene later today, in case you'd like to see more.
    Here are two more images from my Centaur City Scene.
