Thread: Network Rendering on a VirtualBox machine - is this possible?
    Jan 2018
    12
    My main LW installation runs on Mac. Is it possible to use a virtual Windows 7 machine (VirtualBox running on a powerful Linux PC) as a network rendering node?
    Regards,
    Adam
    Avid 'Waver ALPforce's Avatar
    Apr 2009
    Israel
    132
    Should be possible if you are running screamernet executables, I do not know if NRC setup will work. I was running screamernet.exe under WINE for years and years and it worked just fine, was very fast too.
    Jan 2018
    12
    Thank you. I’ll do some tests and report my results. Meanwhile, one more question: in LW 2019 is the Screamernet deprecated and replaced with NRC or they both coexist and can be used?
    Registered User dlvphoto's Avatar
    Feb 2018
    Atlanta, GA
    30
    As long as you have the network in virtualbox set up to allow external connections into the windows virtual instance on the ports that NRC is using, you'll be fine. You may need to NAT them through to the windows instance.
    Jan 2018
    12
