Thread: Tapering instances for stacked objects?
    Aug 2014
    South Bend, Indiana
    429
    Question Tapering instances for stacked objects?
    I am instancing a bunch of blocks and would like to be able to instance a stacked pile like this https://www.shippingcontainertool.co...-1920x1440.jpg
    I tried using a gradient to drive the weight of instances based on their Y position but I end up with floating blocks.
    Any way to achieve this?
    Aug 2010
    Kernow
    2,090
    Here you go...
    Aug 2014
    South Bend, Indiana
    429
    Quote Originally Posted by XswampyX View Post
    Here you go...
    Ahhha! I was going about it all wrong. Thank you!
    Aug 2010
    Kernow
    2,090
    No probs.
    Cheers!
    Aug 2014
    South Bend, Indiana
    429
    So I ran into an issue with this. I have my instances on a container ship and as the boat rocks and goes up and down the instances change since their base position is changing. I cant seem to figure out how to get the "local" base position of the instances.
    Aug 2010
    Kernow
    2,090
    Quote Originally Posted by squarewulf View Post
    Oh!
    I think for this the best bet would be to create a point in modler, then array this point say 30 x 10 x 30 and then just delete a few points up on the top levels such as you have no stray points (up in the air) and then use this point array for your instance creation object.
    Aug 2014
    South Bend, Indiana
    429
    Oh!
    Thats exactly what I ended up doing.
