Thread: TC410 Presets question
    Sep 2014
    London
    98
    Just setting up a TC410+ and having some weird preset issues. I normally set up a preset on my 8000 running AE3 which squeezes layer A back into a smaller box with layer B then revealed behind it, with KEY1 then filling in all the blank areas.
    Layer A is fed from another ME via re-entry, layer B is just an NDI source
    When I take a snapshot of the ME state it shows the picture as I would expect, but when I recall the preset nothing happens, in fact the only thing I do seem to be able to recall is the LIVESET position so if I do a Zoom it works.
    Am I missing something simple here?
    Sep 2014
    London
    98
    Think it may just be me thinking it's got the functionality, just checked the 8000 in the same area it's labelled COMP but on the 410plus it's labelled preset so I'm guessing it's not the same functionality. Happy to be corrected as it will save me writing a complex macro, or going down the after effects route
    1,660
    I don't believe you will have the ANIMATED COMPS on the 410 Plus.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    410 Plus has PRESETS. If you add Premium Access to the 410 Plus you will get COMPS, then it will work just like the 8000.
    Sep 2014
    London
    98
    Gotcha. I'll just go down the AE route then.
    Cheers.
