Thread: One set of bones defore multiple objects?
    digital witchdoctor objuan's Avatar
    Nov 2003
    Denver, CO
    533
    I imagine this is a simple question, but the answer is not jumping out at me. i have several objects, which I want to keep as separate objects for render/compositing purposes, but I want them all to be deformed by the same set of bones.
    I don't want to have duplicate bone rigs, just the one bone rig (which I set up as skelegons on one of the objects) deforms that object, and a couple others as well.
    Help?
    Thanks.
    Ocean Byrne
    humble pixel farmer
    www.moceandesigns.com
    Axes grinder- Dongle #99
    Seattle
    14,732
    Turn on "USE BONES FROM". I disremember where it is. Anyway, just put the armature on a null, and all the objects can share it.
    Praise to Buddha! #resist
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,524
    Select your object, then choose Bones from the bottom menu (Shift-B), then Properties (p). "Use Bones From" is a drop down menu at the top of that panel.
    I typically have multi-layer models for characters (body, hair guides at a minimum), and use this a lot.
    My Scripts for Lightwave
    Nov 2003
    Denver, CO
    533
    Thanks!
    Ocean Byrne
    humble pixel farmer
    If you need several duplicates of the same model character doing the same motion., you could use instances. And there is a way to color each of them differently if desired.
