Results 1 to 15 of 16
Thread: Current camera position
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,357
    Is there a node that gives you current camera position ?
    ITEM INFO node can do that for World Position. Add the node and double click to select which item for it to look at. There is also a node to gain access to all the camera settings.
    -M
    I was thinking of the immortal words of Socrates - "I Drank What??"
    Zagreb, Croatia
    1,357
    Yes but I don't know which camera is current, the node should work for any current camera, not only one specific camera.
    Ah, you are looking for the position of the Current Render Camera. Yup something the Camera node does not have. What is it that your trying to do?
    Zagreb, Croatia
    1,357
    Calculate focal distance with a scene with multiple cameras and camera selector plugin.
    Should be easy with expressions.
    1) make sure each camera has a unique name ex. Camera1, Camera2
    2) make a focus object or null ex. FocusPoint
    3) use this expression: vmag(FocusPoint.wpos(Time)-Camera1.wpos(Time))
    4) add the expression to the camera focal distance envelope
    5) repeat for each camera making sure one changes name in the expression for each camera
    So 10 cameras that all need to focus on the same point in the scene will calculate the distance automatically. Works with the lscript master plugin Universal Camera Selector.
    -M
    Attached Files Attached Files
    May 2006
    France
    4,049
    TrueArt nodes has a Render node with Render Camera ID output?
    Denis.
    Quote Originally Posted by dpont View Post
    Denis.
    Could not find a node that does from his library.
    May 2006
    France
    4,049
    Quote Originally Posted by MSherak View Post
    I didn't check his 2018 library version, so I'm not sure, but in previous version it has a Render Info node.
    Denis.
    Denis.
    I checked his site and he does have a render info node. No camera information node to extract position for focal distance to be calculated.
    May 2006
    France
    4,049
    As I said the output is a Camera ID, for the position you need an Item Info node,
    here in pre-2018, I'm using the DP Kit one, but in 2018 the native one had an ID input too.
    (I'm posting about the first question, not directly about focal distance...)
    Denis.
    7,900
    Yes,
    Render Info node outputs currently selected (by e.g. Camera Selector) camera ID.
    and Extended Item Info has Item ID input.
    May 2006
    France
    4,049
    here in pre-2018...
    I tried the same setup in LW2019, but using this single python node:
    render_camera_node.zip
    It is open source, so you could also easily modify it for outputting other scene infos.
    Denis.
    May 2006
    France
    4,049
    Minor update of this little utility, because I tested it shortly through the Python node loader (Additional Nodes),
    so I remove the useless nodal preview, when it is added as a plugin,
    forgot to say that in this case it is located in Python Nodes/Item Info folder'.
    render_camera_node(2).zip
    Denis.
