Thread: RenderQ
    RenderQ
    Why is it that if you ever open up the RenderQ window it will from then till eternity always greet you when you fire up Layout?
    No biggy - just annoying.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Jan 2005
    Colorado Springs
    1,795
    You can remove it from Utilities=>Master Plugins to avoid having it automatically started when Layout starts:
    mTp
    May 2003
    Ohio
    861
    ...or use the "Render-Q Terminate" command (CTRL-SPACE).
    Thanks. So closing the RenderQ window doesn't "terminate" it? Apparently you can can close the window and the renders will continue on, I've never closed it as I hit the render button and leave the building.
    Tim Parsons
    Technical Designer
    Los Angeles
    7,164
    I just click on the Terminate button beneath the Launch/Open button. This closes and removes Render-Q from the Master Plugins window so it doesn't appear again when you re-launch Layout.
