Results 1 to 8 of 8
Thread: Filling can with nuts
    I have the need to animate nuts falling and filling up a can. I do mostly still work so I'm looking for some suggestions as to the easies way to set up something like this? Even a nudge in the right direction on what tool to consider would be a big help. I assume particals or something like that. Sorry for the basic question.
    Thanks in advance.
    Wayne
    Bullet dynamics would be ideal for this.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Words to the wise, depending on how detailed your "nuts" need to be, consider using proxy objects for any dynamic work. Bake out the motions and replace with hi-res objects and render. You also might want to download Chronosculpt to fix the "jitters" you'll most likely have.
    Tim Parsons
    Registered User motiondigital's Avatar
    Aug 2018
    Australia
    13
    Wayne
    Create 3 layers in modeler
    Layer 1
    model an array of 50 bolts, space them 1mm apart on xy and z axis
    Layer 2
    Create your can and rest it on the ground xyz-0,0,0
    Layer 3
    Create a groundplane say 1 metre x 1 metre and rest on ground
    Send it all to Layout
    Select layer 1 (bolts)
    In the FX tool tab click Parts body
    Select layer 2 (Can)
    Then click rigid body (In the FX tool tab)
    Select layer 3 (Groundplane)
    Then click static body (In the FX tool tab)
    Press play
    Cheers
    Quote Originally Posted by motiondigital View Post
    Wayne
    Layer 1
    Layer 2
    Layer 3
    Press play
    Cheers
    Wow, thanks!
    Wayne
    Motiondigital, is there a way to add some jitter/randomness to the falling objects?
    Thanks.
    Wayne
    You can vary up your starting array.
    www.ernestpchan.com
