Results 1 to 13 of 13
Thread: Mesh Freezing workarounds?
    digital witchdoctor objuan's Avatar
    Nov 2003
    Denver, CO
    533
    I've added 7 copies of a boned figure to my scene, and now every time I render a test frame each figure takes 30seconds "Mesh freezing", and then when the render is done, another 30 seconds "freezing" before I can start editing again. I've set most of them to display as bounding box, and display subd level 1, but that doesnt seem to help.
    Any good work arounds to make this less painful? Most of them dont have to move at all.
    Ocean Byrne
    humble pixel farmer
    www.moceandesigns.com
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,677
    Is your subdivision order set to "last"?
    Nov 2003
    Denver, CO
    533
    Quote Originally Posted by daforum View Post
    Yes. ?
    Not seeing that it makes a difference in this regard whatever I set it to.
    Ocean Byrne
    humble pixel farmer
    14,972
    If you do not have to move them, do not use subpatched surface, freeze it in modeler and do not use any subpatches at all,
    you freeze them at the same level in modeler with the help of the general options in modeler, and there you have subpatch divisions, set it the same as you had in layout if that is what you wanted, then hit ctrl-d to freeze it, then sync with layout again...and don´t subpatch it again.
    Subd level in layout display has nothing to do with the renderer, it is render subpatch level you need to set for it to affect the render.
    But since you do not need to further control subdivisions or have it move, you just freeze it in modeler, and in layout it will render without having to freeze each object.
    San Jose, CA
    6,496
    Just what are render subdivision settings in Layout for the model(s) in question? Unusually high?
    John W.
    Nov 2003
    Denver, CO
    533
    No. 3 to render, 1 for display, and most of them are set to bounding box so in theory it doest not need to display, but every time I come back from rendering a still it takes plenty of time, as does kicking off a render.
    I was thinking along those line Prometheus, though hoping to avoid it. Thanks.
    Ocean Byrne
    humble pixel farmer
    Frequenter
    Sep 2003
    Munich
    349
    I am not in front of LW right now. But would not having the setting for display (3 instead of 1) and render both the same make a difference here?
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,501
    This sounds remarkably similar to the issue FiberFX has, and that has to do with the vparms system within lightwave.
    My Scripts for Lightwave
    Aug 2016
    a place
    1,828
    whats that?
    Feb 2009
    Prescott, IA
    1,501
    FiberFX has a very annoying habit of wanting to update the fiber data for such things and manipulating objects, bones, the timeline, light settings, at alia. Somethings I can see, but at every user interaction?
    Normally, with a few thousand fibers, this isn't an issue. However, moving onto a realistically furred large cat... The lag gets painful. Like 2 minutes for 3 layers of FFX, totalling 4M fibers...
    And then, there is the load / unload when starting / finishing the render, and the excessively long "Freezing mesh" at the start of render...
    May 2006
    Bristol, England
    1,677
    Quote Originally Posted by fishhead View Post
    I think fishhead is right about having the display levels and render levels the same. That should prevent the "mesh freezing" happening all the time.
    Let us know if you resolved the issue.
    Nov 2003
    Denver, CO
    533
    Well sure enough, having Display and Render set to the same number eliminates the long time waiting for it to "freeze" the mesh. It also largely eliminates the purpose of setting a lower display res to speed things up, but glad to be able to deal with this situation quicker...
    Ocean Byrne
    humble pixel farmer
    Los Angeles
    7,156
    Way back when I was with Rhythm & Hues, our Render Submit tool would match the preview and render settings for objects before it submitted a file, with the option to use the scene's settings if you really wanted that. This only affected rendering and didn't actually change the file's settings, and it definitely sped up our renders by avoiding the 'freezing' step.
    I wish LightWave had this feature this natively.
