Thread: Dripping Texture
    May 2006
    France
    4,186
    Dripping Texture
    I added a Dripping 2D procedural texture,
    in all texture and nodal versions of RmanCollect.
    based on a Tristan Michael and Huw Bowles shaders.
    -Apply as procedural texture to surface color, bump channel or any other texture channel,
    also as Alpha channel for just masking another dirty noise.
    -Select "Drips","Drops" or "Overflow" type.
    -Adjust "Frequence", "Amplitude","Drip Density", "Drip Distance" and "Drip Length"
    for both "Drips" and "Drops", some parameter like "Drip Length" has a different behavior
    a lesser effect for "Drops" type.
    "Frequence" and "Amplitude" parameters obviously interact each other.
    -You may modify the bump channel with "Shaded" "Drips" or "Drops" mode with the Amplitude parameter.
    -Adjust just "Frequence" and "Modulation" parameters for "Overflow" type.
    -Use "Time Offset" for animating the whole "Drips" and "Overflow" and falling drops of "Drops",
    while "Drop Speed" can be modified separately.
    Several animated samples,
ID:	145760 Click image for larger version.
ID:	145758 Click image for larger version.
    -These effects are smoothed, but another "Displacement Texture" noise may alter them for realism,
    here, 2 layers of noise masked by 2 Alpha layers of Dripping a bit displaced.
    Denis.
    Murcia, Spain
    3,184
    Wow, thanks very much Denis.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050
    1TB SDD
    32Gb Ram
    LightWave 2020
    Very nice Laptop
    Thanks Denis for this nice addition.
    Eddy Marillat - PIXYM
    WS : MB ASUS X299-Pro/SE - i9 7980XE 2,6ghz 18C/36T - 32GB Ram- 2 GTX 1080 TI - Win 10 64
    GPU Net Rig : MB Biostar - Celeron 2,8 ghz 2C/2T - 8GB Ram - 2 RTX 2080 TI - Win 7 64
    Feb 2012
    Austin, TX, United States
    175
    Denis is so awesome!
    It's better to have tried and failed, than to have failed to try.
    Patreon - www.patreon.com/ernesttx
    Los Angeles
    7,279
    Ok, time for another donation.
    Thanks, Denis. As always, please keep up the excellent work!
    Near Beaverton, OR
    1,939
    Ya know, Denis is gonna have to come up with some sort of Auto Update feature. I finally get the latest version & he adds a few more items a day or two later.
    The Big Apexx System:
    64GB
