Results 1 to 9 of 9
Thread: A Conspiracy of things with Lights
    Near Beaverton, OR
    1,434
    I've been trying to zero in on what's causing this, and tracked it down to where but not why. I'm using ies lights but standard lights exhibit this as well.
Name:	Disco Lights.jpg
    And no, the Disco look is not what I'm after.
    This shows up both in VPR & renders. My usual settings are 2 Brute and Interpolated settings around 314/256 with min/max pixels at 10/100.
    It happens ONLY when using Interpolated; go to Brute Force and the Disco Lights go away but looks pretty grainy unless I really kick it up. I don't use the DeNoiser as it really kills the detail I want to keep.
    Changing the min/max pixel settings with the Interp settings just changes the size of the spots.
    But it also ONLY happens when the light is going through the diffuser geometry. If I move the light so it's not going through the diffuser geom, the spots go away.
    That geom isn't faceted, just simple, smoothed & single sided. Tried a couple glass settings & turning IOR to 1, but still getting the disco lights effect.
    So it seems the culprit somehow is the puck light's glass diffuser but I'm out of ideas what to try. I want to keep the effect of it going bright when the light is on.
    Suggestions?
    Tnx
    Jan 2011
    Seattle
    376
    I see the problem. It's that Carolina Panthers game on the TV. Ha ha.
    Have you thought about using Primitive lights? Then your geo would be the light rather than need to pass through.
    Why would you put it inside the geo? I wouldn't. If you want a certain effect on the diffuser do it in post.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    7,899
    New renderer has a lot of debugging options..
    Scroll down in Render Globals > G.I. to Debug Display Options section, and play with it, one by one.
    ..as usual, turn off one option after option, till the end of effect..
    Then make very simple equivalent scene which is showing problem and send to NewTek in bug report.
    Near Beaverton, OR
    1,434
    Quote Originally Posted by wingzeta View Post
    Yes, tested that earlier & does the same thing.
    Near Beaverton, OR
    1,434
    It may come to that but it still shouldn't behave this way.
    Near Beaverton, OR
    1,434
    Ah gee, do I have to? I just want to light my new sail boat.
    RH's series has a chapter or two on those. I see what they reveal a bit later today. Was hoping some one had see this before.
    Near Beaverton, OR
    1,434
    Taking a closer look at the geom, it's not water tight for one thing. For now, I just moved the lights a bit closer to the diffuser & closed the back of the fixture ring & that pretty much took care of the problem. The original on those surfs just had them as luminous so no real shape to the beam. Although they didn't in this case, in Daz there is some means of attaching an ies profile to luminous surfaces.
    Oh, and swapping out for a much better team helped a great deal.
    I had the exact disco problem on my last job, which was an outdoor scene with tons of lights. I was on a tight deadline though so I didn't have time to mess with it and just turned off the Interpolated.
    ~~Phil Nolan
