Thread: Retargeting Mocap Rhiggit
    Hi I've used Rhiggit for retargeting mocap and its an awesome plugin. Although I have some motion files bought off Turbosquid, the sample file I initially downloaded retargeted straight away with Rhiggit as the bones came into Lightwave fine. But some files bones are coming in like the attached from the fbx yet they seem fine in an FBX viewer.
    To retarget I need to get these files into a T pose to match the Rhiggit Rig. Does anyone know how to make the bones smaller on import to retarget ?
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,492
    The alternative is to make the RHiggit base pose match the initial frame of the mocap as close as possible, which might be a whole lot easier.
    My Scripts for Lightwave
    Nov 2003
    jersey
    5,766
    You can adjust the bone size simply by selecting them all and changing the size option in the bone properties panel.
    As for Tposing... try just setting all the bones rotations to 0,0,0... may work, may not. Depends how the bones were setup during their original creation. If it doesn't... then yes, as K says, the only thing that matters for Rhiggit retargeting is that both characters are in the same pose on the first frame... Tpose is ofc easiest, but any pose will do so long as they're the "same" relative to the 2 characters.
    See the vid...
    https://www.youtube.com/watch?v=6PgNXjHJTv4&t=2m38s
    for a reminder of the idea of "realtive" matched base poses.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    1,390
    Quote Originally Posted by sinelab View Post
    You'll probably just have to fiddle with bone sizes in Layouts UI. Don't know if one Orient Hierarchy in the Rigging Toolbox would help with that or not.
    There's a vid in the original RHiggit made called FBX_Exchange. Don't know if he has it up on 'Tube or not. Also Mocap Editing with FBX-IK in his Foundations.
    Thanks got it working : )
