Results 1 to 15 of 28
Thread: Particle birth from WeightMap
    Jun 2014
    Right here
    1,535
    Is there a way to emit particles from a WeightMap?
    I can add a procedural texture with nodes for the particle birth rate. When I add a WeightMap node and connect it to the value it doesn't work.
    Any idea how to do this in LW?
    I don't recall ever getting weight maps to work with particles properly. I've always just used image maps on uved objects.
    It would be nice if we could use weight maps for particles though, given you can paint weight maps in layout natively now.
    Jun 2014
    Right here
    1,535
    Quote Originally Posted by Ryan Roye View Post
    Thank you Ryan. Yes that's exactly why I'm asking. I'd like to use 3rd Powers PaintWeights to control particle emission (as it works for instances). Still, I think maybe there's a way with nodes to convert the weight map into a greyscale image that can be used.
    15,119
    I think Bryphi77 actually managed to do that in a tutorial he had up on youtube..then he took a lot of them down and including that I think, but he managed through nodel wizardy to get particles to spawn from weightmaps.
    Super Member Chris S. (Fez)'s Avatar
    Virginia
    2,955
    This should not take wizardy. This should be insanely straightforward.
    sure, in a perfect world. I'm also using another app right now by the way, and nope. it ain't perfect either.
    @ OP
    just fast, you can solve it by using a (collision object) displaced eraser object instead.
    the weight painted eraser object must be approached like this >
    bah, why not...   scene >
    Attached Files Attached Files
    Jun 2014
    Right here
    1,535
    Thank you guys, will test it tonight...
    In the Particle Emitter dialog there is no direct Node button like in there is Instances. In the Particle Emitter Birth Rate shading you can select a procedural texture and select Nodes, but they don't work, only some procedural textures themselves unfortunately.
    May 2006
    France
    4,049
    You may have a work around,
    Nearest Point node set to the mesh,
    Point Info set to the Mesh and Weight map,
    but approximate, because it only gives the nearest weight,
    not the averaged weight from surrounding points.
    Denis.
    15,119
    Quote Originally Posted by Chris S. (Fez) View Post
    True....and like this, it also works with fluids emission the same way, and of course..we should have weightpaint natively in Layout...almost a must.
    15,119
    Quote Originally Posted by dpont View Post
    Denis.
    Thanks for the work you do..and great to see you constantly add new textures to the Rman collections, may I suggest one thing though...that would be if you add your newer plugin updates and versions in a reverse chronologic order..so the latest updates would actually be what you see first on your page..instead of having to scroll down to the end of the page.
    Iīm about to check this with particle emission.
    May 2006
    France
    4,049
    ...may I suggest one thing though...that would be if you add your newer plugin updates and versions in a reverse chronologic order..so the latest updates would actually be what you see first on your page..instead of having to scroll down to the end of the page...
    Speaking of th RmanCollect menu?
    It is in alphabetical order since a few weeks,
    may be not what you expect,
    but for retreiving a short doc for a texture.
    Denis.
    15,119
    Denis.
    Thought it wasnīt working...but I figured it out I think, by using a previous layer on top of the procedural node..I got it working..perhaps a math node could be used instead to make it work as well?
    The original setup from the image by Denis did not work though.
    will post the scene later.
    Will also take a look at using metamorphic required for direct layout weight paint.
    15,119
    Denis.
    Nope...I ment the plugins added when updated, the new ones are listed at the bottom of the page, not on top of the page which would be a reverse chronological order so to speak.. wich I feel would be better.
    And thanks for the nodal setup suggestion for weight emitted particles..though I had to add some things to get it working.
    15,119
    And yes..I got it working now..and also with metamorphic weight paint, but any painted or adjusted weightmap with metamorphic will not take affect until you change birth rate or just re-enter the same value, so it sort of restarts the calculation.
    You can also just uncheck the previous layer and re-check it again to activate it..and the particle emission should have been changed to work again...that may be more effective since you donīt have to leave metamorpic but can continue do paint adjust particle emission.
    So voila finally..both weight map paint in layout and particle emission from weight map now possible..but also with the help of Dpontīs tools..not sure you could do it otherwise..but boy the workflow, consider this workflow against what I showed in the blender video.
    2. Next challenge...get the VDB gas solver to emitt from a weight map...I know how to set the gas solver to emitt by procedural density textures, but I havenīt checked weight maps in specific.
