Results 1 to 13 of 13
Thread: LW to Unreal Bridge 2019.1
    Dude! Dillon's Avatar
    San Francisco
    514
    So I tried out the bridge connector to Unreal to see if the image thing has been fixed. Nope.
    Can't manage Principled shaders with multiple images (diffuse, rough, etc) with LW to unreal via the bridge. Only the first image goes over (diffuse) and ignores everything else.
    This makes texturing rather tedious (and actually kills my workflow).
    I've reported this way back when bridge was released. Still not fixed. Even changing out the diffuse image, I can't get it to update in unreal. It keeps to the original diffuse image.
    Any ETA as to when we can work with multiple images for texturing?
    Already submitted this bug/feature lack a long time ago (v 2018?).
    Video and Animation Auteur
    Does the Unreal material do what you need?
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    1,847
    you probably don't want to use the unreal material as you have to select it every time, whereas principled is created by default. If you could set the preferred default material type, that would rectify that workflow issue.
    I have had the unreal materials working correctly with multiple maps via substance and fbx, if that is any good to you?
    San Francisco
    514
    I've succesfully worked with Unreal's principled shader using other apps (substance, etc), but LW Bridge seems to not support multiple images. It's limited to just one, and even after that, can't change the image out. Unreal refuses to update the single image if it's been swapped in LW.
    Bummer.
    LW Dev Team Deep Purple's Avatar
    Europe
    585
    Quote Originally Posted by Dillon View Post
    Bummer.
    Hi Dillon!
    Sending/updating multiple images through the bridge should work, which case # was your bug report filed under?
    Cheers,
    David
    David Forstenlechner
    Software Architect, 3D Development, NewTek, Inc.
    https://www.lightwave3d.com
    San Francisco
    514
    Hi David,
    I'm sorry, I didn't record what # was assigned to my submission.
    I dug a little deeper just now. I now see that there's an error message attached to several images in the material editor for UE; that color modes are set to linear, when they should be set to color. After changing this in the mat editor in unreal, the material and their other images show up correctly. This happens irregardless if I plug an image node (in LW) into the shader via luma or color channel into the shader (principled). If I make a change in LW, unreal errors out the material again, due to the linear/color sample mode being applied to the image. I'm forced to reset the sample color mode from linear to color every time I make a material change in LW.
    Additionally, I now see that after importing via bridge, I was expecting the images to show up in the material folder. They actually show up in the textures folder for the project, not in the imported folder created by the LW bridge import function. That was confusing. I expected the images/mesh/materials to all reside in the folder imported via LW.
    Thanks David.
    Quote Originally Posted by Deep Purple View Post
    Hi Dillon!
    Cheers,
    David
    Europe
    585
    Could you please attach a simple scene to a post in this thread which reproduces the issue for you, and could you tell me which exact version of Unreal Engine you are using?
    San Francisco
    514
    I just submitted a bug report with the requested file. The browser isn't allowing me to upload via NT forum for some reason.
    Unreal 4.22.
    San Francisco
    514
    Oh .. that didn't work. "request entity too large". The 8k jpg images being used are 33MB large. jesus
    San Francisco
    514
    Resubmitted, with super basic/dumb jpg files for images.
    Europe
    585
    Great, thanks Dillon!
    - David
    1,847
    thanks David, for being on here and taking a look at this
    Europe
    585
    Should be fixed in the recently released 2019.1.4!
    - David
