Thread: Expressions help....
    I have a rig Im working on and having a little difficulty figuring out how to setup some expressions to handle the following..
    I have a controller that moves in the Y direction, which controls the movement of eyelids...it moves from -26mm to 26mm
    Along the eyelid are other controllers to fine tune the bones along the eyelid
Name:	Screenshot 2019-08-08 01.20.37.png
    What I need is to move a controller by a certain amount as the controller 0 to 26mm...and then by another amount when the controller moves 0 to -26mm
    I've used the following expression, but it requires the controller be set to its final adjusted position, and then moves it through the whole range of movement of the main controller
    mapRange([EyeLid_Up_Ctrl.Position.Y],-0.0,0.026,0.0,Value)
    Any ideas would he helpful.
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
    Lightwave3D 2019, RF10, Gaea and more..
    Threadripper 32 core , 48gb, GTX-1070
    Asus 752vt i7 2.6 x 4, 48gb, GTX-970
    Aug 2014
    South Bend, Indiana
    400
    Not sure, I don't use expressions ever. But you could try doing it nodaly?
    Ohhh....I always forget about nodes for motions....thanks, I'll give that a try
    Rob Depew
    Web Portfolio
    My Patreon
    YouTube
