Results 1 to 10 of 10
Thread: Offseting characters animation time with instancing
    Can anyone help me and tell me if it is possible to offset character animation with instancing. I have selected the null in which the character bones from mixamo and person object sit. I've set the instances to Parent and set the time offset to 1 and time scale to 10%. All the instances are animating at the same time. what am I missing ? Thanks
    Nov 2003
    jersey
    5,766
    You're missing nothing, it cant be done.
    Only option is to have multiple copies of the actual character setup, time offset those from each other, and create instances of each.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Thanks RH for the quick response saves me from messing with it, that's a shame would save so much time with this feature. I shall begin offsetting : )
    DP instance >
    Thanks Erikals I'll give it go although I'm using Octane to render which I new had a few issues with in the past.
    No problem. If you go with Octane, you'll have to use the RH method, since Octane can't see DP instance.
    Thanks Erikals, yes just done a test looks like I'll have to do what RH said but thank for the input.
    May 2012
    Virginia
    427
    This sounds like something they definitely need to add to instancing. I haven't previously had a use for it, but I could see needing it at some point.
    Aug 2016
    a place
    1,827
    HD instance was cool. I think it stopped at LW10 and 32bit.
