Results 1 to 2 of 2
Thread: Audio configuration TC Mini SDI
    Jul 2019
    Indiana, USA
    Does the output configuration work for the two SDI outputs or are they locked to the master audio? I am trying to setup a mix minus to send the audio from DDR and sound playback to a house mixer and take their feed back with mics to send to an overflow room. I know I need the DDR and Sound players routed to master so they can go out the 1/4" jacks. I am using the line in jacks for their feed back and routing them to Aux1. I seem to have the routing set correctly as I can solo the aux 1 and master to get what I am expecting. I have the master going to Mix 1/SDI and Aux 1 going to Mix2/SDI It shows up correctly on my laptop using NDI studio monitor and records as I expect. I want to use the SDI 2 to go to the overflow room, but both of them seem to stick with the master audio. Is it supposed to work this way or is there something I'm missing?
    Jul 2019
    Indiana, USA
    Update: I stumbled on the this by accident. I selected Aux 1 for Mix 3 audio output and it sent Aux 1 to both SDI 2 and the 1/4" line out jacks. All output configs for Mix 1-4 are accurate for recording and NDI feeds. Not sure if this is a bug or a physical issue with our TC Mini SDI? We are running AE3 Ver 190209. Will try updating after this event and see if anything changes.
