Results 1 to 9 of 9
Thread: Problem with UDIM and a subdivided mesh
    Oct 2017
    Tokyo
    7
    I have a mesh with UDIM textures and I want to subdivide. The problem comes up when subdivide is on, the texture doesnt apply correctly. Looks like it the UV sets (5 in this case) are combine in one. And no matter what kind of subdivide method is used.
    Does anyone knows what is going on?
    What it should looks (NO-subdivided)
    And the problem (After subdivided)
    Mac Pro 2013, 3,5 GHz 6-Core Intel Xeon E5, 16 GB 1866 MHz DDR3 ECC, 2x AMD FirePro D700 6144 MB, MacOS X 10.14.5
    LightWave 2018, LWCAD 2018, ZBrush 2019, Fusion 9, Substance Suite, Affinity Suite.
    You need to change it to subpatch interpoloation.
    Oct 2017
    Tokyo
    7
    Hi, thanks for reply. I've tried using subpatch, as is showing in third image, but the problem still remains.
    What do your UV's look like? This seems like it might be a bug. Have you tried earlier versions of 2018 or 2019?
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Oct 2017
    Tokyo
    7
    Here how it looks like the UV:
    I'm using LightWave 2018.0.7. I will try early versions of 2018. BUT I've realized that the issue only remains in Modeler, Layout has not any problem with UDIM's and Subdivisions.
    Layout render (Interpolation Linear Corners used)
    Oh - okay. Modeler display issue then. Has to be a bug in my book then. The only thing I can think of would be the various GL display options in "d" my rectify it. Especially make sure Legacy OpenGL is unchecked. Otherwise right it off as a bug. You also might want to DL 2019.1 and see if this has been addressed. They killed a lot of bugs in the latest build.
    Tim Parsons
    Technical Designer
    Oct 2017
    Tokyo
    7
    Thanks for reply.
    I've tried in LightWave 2018.0.2, it fails. Then I've tried in LightWave 2019.1 (Demo) and it fails too.
    And I've tried switching GL display options with any success, and Legacy OpenGL is off, as it showed in the screen capture.
    Make a bug report with content.
    Tim Parsons
    Technical Designer
    Oct 2017
    Tokyo
    7
    Bug report sent it!
