Thread: Stream and his fan issues again........
    Aug 2016
    USA
    496
    I'm just trying to get to the bottom of my fan issues.
    Today we did a shoot, recording two cameras. As soon as I hit record, the fans went into tornado mode.
    Again people from down the hall can to see what all of the noise was.
    I got on a support chat with Newtek. I was asked to record a short clip and send it in.
    The session was still open, I hit record and nothing, Still quiet. So next time it gets loud, they asked me to send a clip in.
    My CPU Temp is 67.5 C
    The MOtherboard Temp is 51 C
    With the Tricaster 460 AE2 doing nothing but being on. Those temps seem high, so is the high revving fans due to load, or due to load on a CPU and Motherboard whose temps are past the higher end of the range just being on?
    I'm taking a lot of heat for this, so I'm looking for answers that might be more or different that 'LOAD'
    19,352
    Depending on the age of the system, it might not be a bad idea (assuming you're off warranty) to lift the lid, blow out the hairballs (I'm assuming you have a cat; everyone should have a cat) and make sure the fans are all spinning. I've seen gpu and cpu fans that eventually died, which can manifest in odd ways.
    Aug 2016
    USA
    496
    I will when I'm back in front of it. On the hardware monitor screen it shows all of the fans spinning, but I'll open it up and check for hairballs.
    Cat, dog and birds in the house, not in the studio.
