Thread: TCMINI MOV video recordings different length than WAV audio recordings of same event
    Dec 2016
    Sedona, Arizona, USA
    13
    Question TCMINI MOV video recordings different length than WAV audio recordings of same event
    Hi folks,
    Some colleagues of mine are having a chronic problem, where 2-3-hour MOV event recordings from the TC Mini will import normally into Premiere Pro CC and seem to function normally, but when attempting to synchronize WAV audio recordings of the same event (foreign language translations), the WAV files end up 2-3 seconds out of sync at the end.
    The WAV files were recorded simultaneously during the event, and so there would appear to be an issue with the MOV file-- or perhaps some issue with it in Premiere Pro?
    HD recordings from a Canon XA25 sync perfectly with the WAV files beginning to end.
    The unit is a TC Mini HD 4SDI running AE.
    Any thoughts?
    Thanks so much...
    scott
    TC-1 / AE
    Tricaster Mini HD 4SDI / AE
    Panasonic AW-RP120 Remote Camera Controller
    (4) Panasonic HE-40
    (1) Panasonic HE-60
    (2) Canon XA25
    Gigabit switch
    Dell laptop running SkypeTX
    Aug 2014
    South Bend, Indiana
    379
    I had a similar problem to this and I converted the wav file to mp3 and it worked fine.
    Dec 2016
    13
    Hmmm thanks Squarewulf....it's hard for me to understand how that would help, since an .mp3 is not lossless. Also, we want to maintain the timing of all video which does not have any sync problems.
    TC-1 / AE
    (4) Panasonic HE-40
    (1) Panasonic HE-60
    (2) Canon XA25
    Gigabit switch
    Dec 2016
    13
    UPDATE:
    HERE IS MEDIA INFO FROM A TC MINI MOV FILE WHICH HAS NO SYNC PROBLEMS:
    General
    Complete name : E:\Lam Rim 31\video\07 12_13 morning\MIX 1.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 22.7 GiB
    Duration : 3 h 34 min
    Overall bit rate mode : Variable
    Overall bit rate : 15.2 Mb/s
    Encoded date : UTC 1970-01-01 00:00:00
    Tagged date : UTC 1970-01-01 00:00:00
    Writing application : Lavf52.103.0
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : [email protected]
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 3 frames
    Format settings, GOP : M=2, N=15
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Constant
    Bit rate : 15.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.241
    Stream size : 22.4 GiB (99%)
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Variable
    Bit rate : 165 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 253 MiB (1%)
    HERE IS MEDIA INFORMATION FROM A TC MINI MOV FILE WHICH DOES HAVE SYNC PROBLEMS:
    General
    Complete name : E:\New-ACI-01\files-tim\aci-1\video\class3\video\class 3\class3-tricaster.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 0000.02 (qt )
    File size : 25.3 GiB
    Duration : 1 h 5 min
    Overall bit rate : 55.5 Mb/s
    Encoded date : UTC 2019-04-15 03:01:20
    Tagged date : UTC 2019-04-15 03:01:20
    Writing library : Apple QuickTime
    Video
    Format : MPEG Video
    Format version : Version 2
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, picture structure : Field
    Codec ID : xd5b
    Bit rate : 49.6 Mb/s
    Maximum bit rate : 100.0 Mb/s
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type, store method : Separated fields (2 fields per block)
    Bits/(Pixel*Frame) : 0.798
    Time code of first frame : 20:56:02;28
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 22.6 GiB (89%)
    Language : English
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : in24
    Bit rate : 4 608 kb/s
    Channel(s) : 4 channels
    Bit depth : 24 bits
    Stream size : 2.10 GiB (8%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 20:56:02;27
    Time code, striped : Yes
    Language : English
    ....could the problem have anything to do with variable bitrate for audio or video?
    TC-1 / AE
    (4) Panasonic HE-40
    (1) Panasonic HE-60
    (2) Canon XA25
    Gigabit switch
