Results 1 to 14 of 14
Thread: Where have 'thicken', 'multishift' and 'point normal move' gone?
    Newbie Member wolfiboy's Avatar
    Jul 2007
    Austria, Tirol
    52
    Maybe it's a dump question but where have these tools gone? I'm using Lightwave 2019.0.3. Haven't needed them for a long time. In 2018.0.7 they were still there.
    Usually they should be in Multiply-Extend or Modify-Extend respectively, but they are not.
    Is there a way to add them manually?
    pass:sword OFF's Avatar
    Russia
    1,010
    In my case, everything remained in its place. In 2019.1 everything is in the same place where it was in 2018.07.
    Jul 2007
    Austria, Tirol
    52
    I'll give it a try with 2019.1 . Downloading now...
    Ohio
    839
    Can you locate them with CTRL-SPACE?
    Murcia, Spain
    3,012
    Are they legacy plugins now, should not be but check the legacy zip.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Frequenter
    Munich
    349
    They are all regular PlugIns. At least to my knowledge:
    Thicken: Multiply-Tab/Thicken.
    Multishift also Multiply-Tab.
    PointNormalMove via Modify/More (on a 1200px vertical resolution here, on a real hires probably in plain sight..)
    Murcia, Spain
    3,012
    As i said i could not see any reason why they would have been reverted to legacy.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Ohio
    839
    Somebody needs to submit a feature request so that you could just hit a hot key (let's say "CTRL-SPACE") and then start typing the command/plugin you want. Then a pop up menu appears where you can either hit ENTER or click on the command/plugin to run it. To make it even better, this pop up menu could show where in the menu system the command/plugin exists.
    Here's a mockup of what that might look like...
    Funny!
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Jul 2007
    Austria, Tirol
    52
    Well, in 2019.1 the three tools are present again at the right spot in the menu.
    Jul 2007
    Austria, Tirol
    52
    @JohnMarchant: Thank you John for the information but here comes another dump question: Where do I find the legacy zip? Or do you mean zip-files of older LW-versions?
    Murcia, Spain
    3,012
    There is a zip file called legacy, its in the support/plugins folder where you installed LW. It contains some older plugins that are there for, well legacy. If you have some older assets or scenes that need them.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Jul 2007
    Austria, Tirol
    52
    Thank you, good to know.
