Results 1 to 8 of 8
Thread: Automated material, node, or envelope import/export
    Wary Lamb Rejoining Flock Scott Gammans's Avatar
    May 2003
    Suburban Washington, DC
    258
    I’ve developed a small c# program that generates a set of envelopes for a couple of input channels in 20 different material nodes in one of my models. The output of the program is a set of 20 version 1 *.node files that I can then import into the node editor and hook into the material nodes of my model.
    It works just fine, but whenever I regenerate the envelopes (which causes 20 new *.nodes files to be generated), I have a VERY tedious and repetitive-stress-motion-inducing chore of:
    • Press F5 to see the surface editor
    • Double click a surface to bring up node editor
    • Select the node that needs to be replaced
    • Delete the node (and its inputs and outputs)
    • Import the new node from the newly-generated *.node file
    • Reconnect the new node to its inputs and outputs
    And then repeat this another 19 times for the other 19 surfaces.
    There has GOT to be an easier way to do this. Is there a plugin or obscure command I’m missing somewhere where I can set up a persistent (i.e., “memorized”) list of surfaces in my model which, on demand, looks for and replaces certain nodes in their materials with new nodes from a *.nodes file? I’d even settle for a way to set up easy updating of just the envelopes for certain channels, while leaving the rest of the node (including all those connections) intact.
    I know I could probably do this with Python or LScripting; I just don’t want to delve into that if there’s already something available that’s already in LW or doesn’t cost a hundred bucks. Thanks!
    7,891
    Check out TrueArt's Global Material
    http://globalmaterials.trueart.eu
    It creates one global Node Editor for the all objects the all surfaces (or the one that you want to).
    It works with LW 11.x, LW 2015.x and LW 2019.x (separate versions).
    May 2003
    258
    Thanks. I had heard of their plugin before but it won’t really solve this particular issue (all 20 of the envelopes are different, so applying a class-based nodal system on top of LightWave won’t help). Their solution *would* be useful elsewhere; LightWave’s node editing system cries out for a more object-oriented approach. What gives me a moment’s pause is wondering whether they’re doing something hinky with LightWave’s node editing system to graft their object-oriented material system on top of LightWave’s.
    May 2003
    258
    Sensei, does Global Materials work with OctaneRender 2018 and the LightWave plugin for OR?
    you can also look at nodemeister from dbw .. that one supports octane for sure.
    Oliver
    OD Tools Purchase Link: http://origamidigital.com/cart
    Vimeo Channel: https://vimeo.com/channels/850417
    Join ODRoot - https://www.odroot.com
    May 2003
    258
    It sure looks like what I'm looking for... downloading an evaluation copy now to check it out. I appreciate the tip!
    Sensei, if TrueArt's Global Materials works in a similar fashion, supports OctaneRender, and also has an evaluation mode, please let me know.
    Thanks guys!
    7,891
    Octane uses some proprietary materials, not LW standard materials.
    May 2003
    258
    Hi Sensei! Yes, I know; that's why I asked whether TrueArt had worked with OTOY to add support for OctaneRender materials and textures (which db&w did with nodeMeister's 2018.1 point release). Oh well, it was worth a shot; thanks for confirming!
    Oliver: After fooling around with nodeMeister I've decided to give it a try. It definitely has its "quirks" but I'd be willing to bet at least some of what I ran into during evaluation could be chalked up to the creaky LightWave SDK (or even OctaneRender's API). (Besides, after living with LightWave on and off since version 7.5, I've gotten into the habit of hitting S, Shift-S, and Alt-S almost reflexively!) But even with the quirks, I can already tell this will save an enormous amount of clicking and copy-pasting. Thanks again for the tip!
