Results 1 to 12 of 12
Thread: collapsing floor in bullit
    Nov 2018
    belgium
    6
    How can i collaps a floor in such a way that the pieces doesn't fall at the same time but in a linear way or from the centre of the floor too the edge.???????
    Thanks in anticipation.
    A weight map could be used to affect what falls first to last.
    Do this through the nodal system.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    For something like this?
    https://vimeo.com/157240124
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Jan 2005
    Colorado Springs
    1,822
    For this sort of "managed destruction", I'd Fracture the floor object with a centered Sphere in the backtground layer to make the fractures more dense toward the middle of the floor, set the Glue Strength to 100% on the Parts Body floor, and use a moving Bullet Collision object which "unglues" the Parts of the floor over time using a Gradient on Distance to Object. Sample scene attached.
ID:	145483 Click image for larger version.
ID:	145485 Click image for larger version.
ID:	145487 Click image for larger version.
    MOV file: Bullet_FloorDropAway_Simple_MovingCollisionObject.mov
    In Modeler, you create a Floor object and a surrounding Foundation with a ledge to support the edges of the floor as it falls apart:
ID:	145490 Create unfractured floor
ID:	145491 Create foundation with ledge using Boolean subtract, Knife, Extend
ID:	145492 Create spherical object for background Fracture polygons
ID:	145493 Set up Fracture using background polys
ID:	145496 Fracture results
ID:	145494 Create Bullet Collision object (will be hidden)
ID:	145495 Rename all layers for clarity using F7
    Save the object and send it to Layout.
    In Layout, the Floor_Unfractured layer isn't a Bullet object, but is just there to dissolve to 100% when the Floor_Fractured Parts Body starts falling apart. Here's the other Bullet setup:
ID:	145497 Set the Foundation to Static Body
ID:	145498 Completely hide the Background Fracture Poly object
ID:	145499 Set up the Floor_Fractured layer as a Parts Body with a Gradient=>Distance to Object on Glue Strength
ID:	145501 Parts Body Activation is Start Sleep (until touched by Collision Body)
ID:	145500 Bullet_Collision layer is Bullet Collision object, Moved up so it doesn't touch the Fractured Floor initially
ID:	145502 Bullet_Collision also set completely hidden
    The background fracture polygon layer and the Bullet_Collision layer are completely hidden by using the Object Properties=>Render tab and setting Unseen by Camera, etc. and clearing all the Shadow options.
    With Dynamics Disabled, create a motion path for the Collision object to unglue the floor:
ID:	145503 Dynamics Disabled, move Collision object
    MOV file: Bulllet_FloorDropAway_DynamicsDisabled_MoveCollisionObject.mov
    Turning on Dynamics, use Front View to determine when the Floor_Fractured body starts falling apart, and Dissolve the Floor_Unfractured object (not a Bullet participant) to show the fractured floor using an Envelope:
ID:	145505 Dissolve the Floor_Unfractured object (not a Bullet participant)
    Add some texturing, setup the backdrop:
    Enable VPR so the hidden objects and dissolve shows, fine-tune the Parts Body parameters and the Collision object motion:
    Have fun!
    mTp
    P.S. Note that the uploaded animation isn't from the attached sample scene. The sample scene was recreated from scratch to provide the screen shots. I actually think I like the sample scene animation better, although I wouldn't move the Collision object down to Y=0 so there aren't so many floor fragments which "explode" upward.
    Last edited by MonroePoteet; 07-18-2019 at 11:00 AM. Reason: P.S. Uploaded MOV file of animation isn't sample scene
    Jan 2005
    Colorado Springs
    1,822
    Here's the sample scene with the Collision object motion and unglue gradient fine tuned to have a larger close-to-zero Glue Strength area around the collision object.
    MOV file: Bullet_FloorDropAway_SampleScene_FineTuned.mov
    mTp
    Frequenter
    Munich
    386
    I donīt know how happy the OP with your directions but I feel the strong urge to just praise you, MonroePoteet, for your amazing support of the community!!! You are a real asset for all lightwavers out there! Kudos to you - tons!!! :-)
    Jan 2005
    Colorado Springs
    1,822
    Thanks! I enjoy helping out when I have the time, and I'd done this sort of simulation before. That "unglue by distance to object gradient" is a powerful technique for "managed destruction", allowing a Bullet Parts Body to be torn apart / destroyed under control of the referenced object by moving it around. For example, multiple bullet hits on a wall, or here's a really old, simplistic animation I did of a laser beam tearing apart a concrete wall using the same technique:
ID:	145521 Click image for larger version.
ID:	145523 Click image for larger version.
    MOV file: ConcreteWall_LaserBeam.mov
    Again: Have fun!
    mTp
    Nov 2018
    belgium
    6
    YES!!!!!!.Thank you for your reply
    Marc
    Jan 2020
    plano
    I like i like
    The gift of life is today and for the future
    Home maintenance
    Neat!     
    Pessac
    5,112
    I don't want to be snippy or denigrate MonroePoteet in any way, but there has been a tutorial for managing destruction in the LightWave wiki for a couple of years now, and it was based on one I wrote for the PDF about eight years ago...
    https://docs.lightwave3d.com/display...ur+destruction
    And Monroe kindly agreed to share his method for the docs too:
    https://docs.lightwave3d.com/display...or+Destruction
    "Respect the research!"
    B
    LightWave 3D Trial Edition
