Thread: Editing Morphs
    Near Beaverton, OR
    1,343
    Editing Morphs
    I've come across a nice older model of a ship with several morphs for the sails that I've exported as a FBX. On semi-simple models such as this, that's never been a problem with the morphs, but with this model, all of the morphs are also translating the geom neg Y for some reason. Tried an earlier FBX version and same issue.
    I'll attach the Jib model with just 3 morphs as an example if anyone cares to look:
    Lic-Jib_2791.Shape.lwo
    Any suggestions on how to go about fixing these?
    Tnx
    7,891
    Select 1st morph, use Modify > Move, set Offset Y 6.5m, Apply.
    Switch to 2nd morph, use Modify > Move, set Offset Y 6.5m, Apply.
    Switch to 3rd morph, use Modify > Move, set Offset Y 6.5m, Apply.
    Near Beaverton, OR
    1,343
    That's pretty much what I tried earlier but it wasn't working. Maybe I was using the wrong tool. Will recheck later today.
    7,891
    I did it the way I described prior writing post and worked fine.
    Near Beaverton, OR
    1,343
    Just tried again & working. Very odd but thank's for the confirm.
