Results 1 to 10 of 10
Thread: VLC Plugin not being installed with NDI Tools 3.8, VLC 3.0.7.1
    Registered User roddyp's Avatar
    Sep 2017
    UK
    60
    I've reported this on Fogbugz, which hopefully is still the correct way to get this logged?
    Anybody else seeing this issue?
    https://fogbugz.newtek.com/default.asp?100912
    Nov 2018
    nairobi
    2
    me . Did you get a way out? having same issue
    Mar 2016
    Houston TX
    32
    I noted that the NDI|HX driver was not installed with NDI Tools 3.8.
    https://fogbugz.newtek.com/default.asp?100695
    Failure of the installer seems a common theme.
    Sep 2017
    UK
    60
    Quote Originally Posted by fauzia View Post
    I had another machine with an older VLC installation. I just copied the NDI plugin file from that machine to the one with upgraded VLC and it works fine.
    Aug 2019
    minnesota
    2
    I also noticed that the VLC plug-in was missing after installing NDI tools. I downloaded the tools installer again (just yesterday) and tried re-installing, same thing, no VLC plug-in.
    The NDI Tools 4 installer does find VLC 3.0.7.1 and install the plug-in, I know this version isn't available yet, but wanted to let you know.
    Registered User davedude's Avatar
    Jun 2009
    San Antonio, Texas, USA
    148
    Thank you Kane! Any ETA ?
    Sep 2017
    UK
    60
    (oops! version trouble, now sorted.)
    I just tested VLC 3.0.8 and the latest NDI Tools 3.8 download and everything is installing without issue.
    May 2012
    Worthing
    166
    I have just upgraded to NDI 4 and then upgraded VLC to 3.08 and I no longer have the NDI Plugin in VLC.
    Update:
    I have just re-installed NDI Tools 4 and the NDI Plugin is NOT list in the codecs on VLC. I'm sure this is due to the NDI installer not putting the codec into the same folder that VLC uses for plugins.
    SORRY:
    i have found it, it must be my brain or my eyesight.
