Results 1 to 2 of 2
Thread: [LINUX] NDI Failover not working
    Jul 2019
    Netherlands
    5
    Hi All!
    I've backported NDI from CasparCG Server 2.2 to CasparCG Server 2.1, and have added some functionality to set a failover NDI source via config file.
    Setting it works fine, and for example the windows studio application fails over nicely if I shut down CasparCG
    However Linux NDI consumers I've tested are not failing over; I've tested with both OBS-Studio and OBE-RT encoder neither seems to failover to the backup source. Both use 'NDIlib_recv_capture_v2' to capture, is there a setting I'm forgetting to set somewhere on the connection or elsewhere?
    Jul 2019
    Netherlands
    5
    Any NDI Devs that can comment on this?
    NDI Failover (receiver side) on Linux?
    As said in the OP: the windows monitor application is failing over correctly, however Linux Receiver is not.
