Thread: Recording source in c# examples
    Jul 2019
    Netherlands
    2
    Hi All!
    I have the examples working so far.
    I send screenshots to the sender and that all works!
    What i can't seem to figure out and cant find any documentation about is how to record the stream.
    the
    Code:
    _canRecord = NDIlib.recv_recording_is_supported(_recvInstancePtr);
    alsways returns false.
    Also
    Code:
    // frame settings - check for extended functionality
                    case NDIlib.frame_type_e.frame_type_status_change:
                        // check for PTZ
                        IsPtz = NDIlib.recv_ptz_is_supported(_recvInstancePtr);
                        // Check for recording
                        IsRecordingSupported = NDIlib.recv_recording_is_supported(_recvInstancePtr);
                        // Check for a web control URL
                        // We must free this string ptr if we get one.
                        IntPtr webUrlPtr = NDIlib.recv_get_web_control(_recvInstancePtr);
                        if (webUrlPtr == IntPtr.Zero)
                            WebControlUrl = String.Empty;
                        else
                            // convert to managed String
                            WebControlUrl = NDI.UTF.Utf8ToString(webUrlPtr);
                            // Don't forget to free the string ptr
                            NDIlib.recv_free_string(_recvInstancePtr, webUrlPtr);
                        break;
    is never run.
    but when i installed IsoRecorder i can record the same input without problem?.....
    Am i missing any flags/options i need to set to be able to record?...
    My main Sender Functions:
    Code:
     // callback function, called when a new screenshot is taken.
            private static void Render(object sender, Bitmap image)
                if (!Directory.Exists(imageFolder))
                    Directory.CreateDirectory(imageFolder);
               // string str = $"{DateTime.Now.Minute.ToString()}{DateTime.Now.Second.ToString()}{DateTime.Now.Millisecond.ToString()}";
                //image.Save(Path.Combine(imageFolder, $"{str}.bmp"));
                BitmapData data = image.LockBits(new Rectangle(0, 0, image.Width, image.Height), ImageLockMode.ReadOnly, PixelFormat.Format32bppPArgb);
                videoFrame.BufferPtr = data.Scan0;
                sendInstance.Send(videoFrame);
                image.UnlockBits(data);
            static void Main()
                failoverName = String.Format("{0} (NDIlib Send Example)", System.Net.Dns.GetHostName());
                sendInstance = new Sender("Example", true, false, null, failoverName);
                videoFrame = new VideoFrame(1920, 1080, (16.0f / 9.0f), 1000, 30);
                audioFrame = new AudioFrame(1700, 48000, 2);
                bmp = new Bitmap(videoFrame.Width, videoFrame.Height, videoFrame.Stride, System.Drawing.Imaging.PixelFormat.Format32bppPArgb, videoFrame.BufferPtr);
                ScreenShotThread = new Thread(new ThreadStart(ScreenShot));
                ScreenShotThread.Start();
                Console.ReadLine();
            } // Main
    Aug 2015
    london
    228
    Quote Originally Posted by Wyvern_010 View Post
    Hi All!
    The NDI Record function you mention is really asking if the sending device is capable of recording *itself*. For example an NDI PTZ Camera with an on-board SD card recorder.
    ISOCorder is actually doing all the work itself to receive the frames in the normal way and then encoding that disk.
    Jul 2019
    Netherlands
    2
    Thanks for your response!
    Guess i will be going deeper into the rabit hole.
    Any recomandations to library that do most of the work for me/us? (something with re-inventing the wheel)
    Currently experimenting with AForge/Accord
