Results 1 to 13 of 13
Thread: CPU usage Critical.System currently using 90.9 % CPU
    Jun 2017
    Rutland, VT
    11
    Hi all,
    When I recently exported a video from my TriCaster Mini (Advanced Edition) to a hard drive plugged into a USB3 port and I got the following message:
    "CPU usage Critical.System currently using 90.9 % CPU"
    What does this mean? It doesn't sound good.
    The last video we recorded, has skipped frames in it, and I'm wondering if it's related to this issue. Is there something I should do to the TriCaster?
    Thanks!
    Daniel
    Jan 2018
    Winter Park
    282
    Were you exporting while switching/recording?
    Jun 2017
    Rutland, VT
    11
    Quote Originally Posted by stp_productions View Post
    No, nothing else was going on. When I do record, then I have other issues (which might be related?) where it recently started saying "Record Warning drive may not be fast enough"
    So I tried defragging the hard drive and that didn't seem to fix it.
    Then I ran some updates - and now it's even worse. When I open up the project most of the screen stays black - see the picture attached.
Name:	TriCaster Screen.jpg
    I can still move the mouse and macros work, but I can't access any menus or click anywhere with it all black ... Any suggestions?
    Daniel
    Try a new session and see if it opens up correctly.
    Jun 2017
    Rutland, VT
    11
    I tried a new session and it was also mostly black, but the keyboard shortcuts still worked and I could move the mouse around. I tried randomly clicking around where buttons should be, and the screen items appeared. I went back into my main session, and the same thing happened:
    https://www.youtube.com/watch?v=Q9Sw...ature=youtu.be
    Every time I exit and return to the sessions it's the same thing as the video above.
    So I've got three issues, that I think are all connected: (1) most of the screen black when opening a session, (2) skipping sections while recording and saying "Record Warning drive may not be fast enough" and (3) while transferring files the "CPU usage Critical.System currently using 90.9 % CPU" message
    Jun 2017
    Rutland, VT
    11
    Someone recommended I try downloading and installing just the latest software by itself. I tried to do it and I got error messages. See the video below.
    https://youtu.be/AYOExaPkyxs
    This TriCaster is really having issues. Is there a way I could reinstall the software and start over?
    Thanks,
    Daniel
    19,352
    Quote Originally Posted by Appelt View Post
    That's what the TriCaster Restore feature is for. It's in the docs, but someone will probably jump in an explain it. I just wanted to mention that, when you wrote "Then I ran some updates - and now it's even worse", I was hoping you meant 'TriCaster updates', as opposed to something else.
    Also, If a Restore followed by updating again doesn't solve this, I'm starting to wonder whether you might have some sort of overheating condition going on. Probably not, but a thing to keep in mind if all else fails.
    Jun 2017
    Rutland, VT
    11
    Yes I meant TriCaster updates - but I wonder if I goofed it up when doing it. You see, when I clicked update, nothing happened. So I clicked it several more times before a window popped up. Then I went through the boxes (agreeing to terms, waiting for it to install, etc) several different times. It's been awhile since I'd done any updates, so I thought it might be just updating several different things. But all the windows looked the same (I should have paid more attention to what they were), so now I'm wondering if I could have messed it up by somehow installing multiple copies of the same updates? Could that even be a thing?
    Thanks for the tips for the Resore feature - I'll see if I can find it.
    19,352
    I think it could.
    Jun 2017
    Rutland, VT
    11
    So, today I tried to restore the TriCaster. I did a “Restore system partition to factory default.”
    But then when I tried to update, it was a box asking for the registration code. When I tried to go through the steps, it said it was already registered. When I entered the registration number I had previously, it would just close the box not update anything. When I clicked update again, it would just ask for the registration again.
    So I did the "Restore system partition to factory default" again. And now when I click on update, I get a "This page does not exist" error message, that says the same thing in a bunch of languages.
    Also, when I log onto a session, a box pops up with the message “HDBASE. Load capacity is not set to 6 pf, resetting manually” with the options to either reset, abort, or ignore.
    Hope I didn’t make things worse...
    Daniel
    19,352
    I think you need to have a long talk with Customer Services.
    Jun 2017
    Rutland, VT
    11
    I started talking with support yesterday and they opened up a ticket, but I thought I'd keep updating the progress here. I'll let you know if we get the problem resolved. Thanks for your help.
    Jun 2012
    peru
    371
    same problem here, I received the same message all the time but the videos that export dont have any problem.
    Tricaster is the best thing that i've used since I played with my atari
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
