Results 1 to 8 of 8
Thread: clip map
    Sep 2010
    Kuwait
    234
    clip map
    Hi ll
    regarding to clip map ,, we know its under object properties ,, but can I use clip map in surface editor in the Node Editor?
    thanks
    Yes, but only in the 2015+ versions. Before this, it wasnt possible.
    Sep 2010
    Kuwait
    234
    oki ,, I'm using now LW 2019
    and can I do with clip map in the surface editor ( two object like two balls one mesh and the other Solid not showing using Null ( moving null from down to up ) start appear the solid ball) ,,,
    I hope I describe everything ..
    I am Yamini and I am new to the Forum.
    Jan 2005
    Colorado Springs
    1,855
    Yes, you can use a Null to clip geometry as it moves around. The simplest way is to use a Layer=>Scalar node as a Gradient, with the input set to Distance to Object where the Object specified is the Null. Sample scene attached:
    MOV File: ClipMap_DistanceToObject.MOV
    The node setup is:
    mTp
    Attached Files Attached Files
    Sep 2010
    Kuwait
    234
    Great Thanks onroePoteet:
    Another thing ,,, Where can I find the Displacement Node ,, I tried to search about Dis, Node in the object properties ,, but I couldn't find it
    Member adhesiveX's Avatar
    Tennessee
    184
    Glad your here my friend. You're going to love this ride.
    Sep 2010
    Kuwait
    234
    Hi adhesiveX ,, how R U Friend ..
    Nice to hear from you here, I'm fine except that LW 2019 is different than be4, it become more difficulty .... but hope to gain more experience from you and from our friends..
