Results 1 to 2 of 2
Thread: NDI Virtual input, default camera
    Jun 2019
    Ireland
    1
    I am using NDI cameras for Lecture Capture using a windows computer running Panopto. I can schedule recordings remotely using Panopto, but because you have to select the camera on the Ndi virtual input software every time you re boot the PC. The NDI cameras are useless in this scenario, unless i can set the software to remember the default camera. Can you guys at NEWtek build in this feature or has anyone out there found a work around for this?
    I think it already does this. I believe you need to set your NDI source, then manually exit out of Virtual Input so it saves that selection, then the next time is starts it will automatically pick the source back up.
    I just tried and NDI Virtual Input picked up my NDI source after a reboot.
