Thread: Skype fails to see NDI Audio feed from camera
    Mar 2019
    San Francisco
    13
    I'm running Skype with the NDIHX-PTZ1 Camera, using the NDI Virtual Input application. I have a post-mix feed running into the Camera Audio Input via 3.5mm cable.
    Skype sees the camera and the video feed, but sometimes doesn't see the NDI audio feed (no levels). If I toggle between None and Camera in the Virtual Input settings, that will get the NDI audio working. Sometimes when I start and connect a call, Skype says there is a microphone error - the microphone settings have changed and the NDI audio stops working. Toggling between none and the camera in the Virtual Input settings again will fix this. Sometimes I need to restart both applications.
    Is there a way to ensure that the NDI audio connection will always work?
    Skype 8.46.0.60 (not from the Windows story)
    Windows 10
    NDI Tools 3.8
    NDIHX-PTZ1 Camera with 3.5mm audio input
    Mar 2019
    San Francisco
    13
    Confirming that trying to use NDI audio as also a problem with Zoom conferencing. Luckily, Zoom can see the system audio, so I can select the audio source as "Stereo Mix" and run NewTek Studio Monitor for an audio feed.
    When I use "Line (NewTek NDI Audio)" as a microphone source, while running Virtual Input, the audio quality is quite bad. In fact, there are often click sounds like there is a bit rate issue. Will there be a solution from NewTek?
    Jun 2019
    Washington, DC
    4
    I am experiencing same audio issues with both Skype and Zoom. I have the camera video feed but no audio. I am using a mic connected to the PTZ camera audio input. Any fix to this issue?
    Mar 2019
    San Francisco
    13
    My fix is to incorporate a USB DAC, like the Focusrite Scarlet into my workflow. Because laptops don't have mic inputs anymore, I had to find a USB solution. Windows 10 has drivers for the Scarlet and it works "out of the box"
