Thread: some beginner questions (rotate and place perpendicular on polygon)
    Jan 2018
    Ned
    15
    I have some questions:
    for example if i have a cube in Modeler this cube has already been rotated. How can i rotate this cube on his own x,y and z axis?
    (how i do it now is in the 3d view i will try to get the view as good as possible so i can rotate with 'y')
    Is it possible to place a polygon of a selection perpendicular or parallel to another polygon?
    Use Aling tool (with gizmo) to place it on top of another polygon and then Translate tool with gizmo for rotating/moving (RMB is for moving gizmo and LMB is for usage)
    RAM-Studio
    Super Member vncnt's Avatar
    Amsterdam
    1,570
    Modify -> Rotate.More -> Rotate To Object
    Select [1] the destination polygon, [2] the source polygon, [3] the other polygons that need to rotate with the source polygon.
    Then press Rotate To Polygon.
    Jan 2018
    Ned
    15
    Thank you!
    Some very useful tips! ^^
