Results 1 to 9 of 9
Thread: gradient color
    gradient color
    Hi everyone, I'm learning to use the program. My test is that of the image, the purpose was to create green "spots", which I did simply by applying to a TURBULANCE node. I also wanted the green spots to have at least two colors, light green in the center and darker green on the edges. I tried to add a GRADIENT node with two colors and set it correctly, but nothing to do ... I hope I explained myself ... Someone at a suggestion ... Thanks
    England
    5,837
    Share your node flow too, in a screenshot... might help us a bit.
    Desk Work:
    Desk Home:
    Aug 2010
    Kernow
    2,072
    Like this?
    This node...not function !!! Sorry
    this is my NODE...Click image for larger version.
ID:	145293Click image for larger version.
    Aug 2010
    Kernow
    2,072
    Quote Originally Posted by alviparma View Post
    Ahh... You are mixing up your colours with your alpha's. If you are mixing materials then colour won't be relevant. To mix materials then you need two separate distinct surfaces and an alpha value to mix them.
    Try :-
    sorry XswampyX but you can not, I still have only one color on the green spots !!!! How should I do ????
    Hi XswampyX, can you kindly send or attach the LWO file you made for this example ??? thanks a lot
    Aug 2010
    Kernow
    2,072
