Results 1 to 15 of 15
Thread: Those Lousy, Leaky Lights again
    Near Beaverton, OR
    1,346
    I filed a bug report on this a long time ago. Heard nothing and this has been going on since 2018. So, maybe it's time to start squeeking a bit louder.
    New set, same issue. This time the lights are simple point lights in sconces. For testing purposes I made sure ALL surfaces had 0% spec, Glossy reflections OFF, and Raytrace only and gave the point lights different colors in order to see the culprits. The walls have geometry, not single sided polys.
    I made a wire overlay, & as you can see from the positions of the sconces in the outer hallway that they're completely ignoring the geometry.
    And yes, these render, it's not just a VPR issue.
    Is there a remedy for this? Going in & excluding things for the lights is just stupid and in this case not really possible. The lights shouldn't be doing this in the first place. Or is there something I've completely overlooked?
    Near Beaverton, OR
    1,346
    Well, I was overlooking something. Point lights at least get added with Ray Trace Shadows OFF. Turning those on they now respect the geometry.
    I haven't encountered this yet. Does it just happen with point lights or other light types?
    Near Beaverton, OR
    1,346
    Tested with a few other types & they do it too. I'm a bit baffled as to why THAT is the default. I mean, where would you use that in the first place; a light that shows through all of your geometry?
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    Are your sconces 'shell' geometry, ie, just single sided?
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Near Beaverton, OR
    1,346
    No, they're fully modeled & using a dielectric surface.
    Point lights in 2019 behave oddly. I've pretty much stopped using them because I get all kinds of errors with them. Instead I either use a spotlight set to a high angle or a spherical light (though those tend to chew up render time)
    Rob Depew
    Modeler/Animator/Editor
    Web Portfolio
    My Patreon
    YouTube
    Lightwave3D 2019, RF10, Gaea and more..
    Threadripper 16 core , 48gb, GTX-1070
    Asus 752vt i7 2.6 x 4, 48gb, GTX-970
    Dec 2004
    Gold Coast
    3,171
    What's the report number?
    Near Beaverton, OR
    1,346
    Quote Originally Posted by lwanmtr View Post
    I didn't want to go through the process of primitive lights for the sconces light I did for the other practicals I added. Outer hallway, above the eyeline... But it now expains issues way back with 2018 that I could never resolve.
    I'd say give 'em a try again, just remembering to enable shadows.
    San Jose, CA
    6,485
    It sounds more like coincidental side-effect, not an intentional effect of that control -- as you note, lights generally not obeying geometry isn't particularly useful, esp. without at least control over which geometry gets ignored. If that's indeed the default, then that also seems like a UX issue, even if it only impacted shadows' behavior.
    If that IS intentional behavior for that control, it shouldn't be. Even setting the default setting UX issue aside, that's horrible labeling as well, because whether shadows are ray-traced and whether lights obey geometry really aren't the same thing -- they're conceptually related impacts, but still represent significantly different use case scenarios. Better the two effects should have independent controls, and ensure the "obeys geometry" setting supports inclusion/exclusion control.
    John W.
    If you want to create unnatural glows, etc then having a light that will show through all your geometry is useful.
    Rob Depew
    Web Portfolio
    My Patreon
    YouTube
    Near Beaverton, OR
    1,346
    But not as a default though certainly.
    Maybe its a test to see if folks are paying attention to settings...hehe
    Rob Depew
    Web Portfolio
    My Patreon
    YouTube
    England
    5,837
    I've tried it here, and point lights are added with shadows enabled. Maybe it's some weird config issue? Worth deleting them, to see if it's that?
    Desk Work:
    Desk Home:
    Near Beaverton, OR
    1,346
    Last night I added some point lights to a new set & they came in with Shadows enabled so you might be correct. I've had a few other "I know I set that" quirks. Worth keeping an eye on anyway.
