Thread: Using an image sequence in a timeline?
    Jan 2008
    fl
    12
    I know how to set an image sequence in the image editor but is there a way to make it go off a certain times?
    I want it to go off at the beginning but I also want to to go off again at frame 65.
    Jan 2005
    Colorado Springs
    1,794
    You can set the length of the Image Sequence to 65 and then set Post Behavior to Loop. As an example, here's the Image Editor panel setting the sequence to 60 frames long (the actual sequence is 240 frames), and then looping back to the beginning every 60 frames:
ID:	145233 Set Length to 60 frame
    If you ONLY want the sequence to start at zero and again at 65, I think you'd need to use the Image Editor=>Clone=>Duplicate to make a copy of the Image Sequence, and then set the Start Frame to 65.
    mTp
    Jan 2008
    fl
    12
    Yeah I do want the sequence to go off at certain different times instead of a repeating loop. I will look into the cloning technique. Thanks!
    If you have the db&w plugin frameD you can essentially create a playlist for your images.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Dec 2009
    London, England, UK
    1,045
    Blog Entries
    18
    Quote Originally Posted by Noval View Post
    You could try this:
    In the Image Editor, load your sequence and make sure it's set to sequence in it's settings.
    Select the sequence name from the Name list and clone it as Clone>Duplicate.
    Select the newly cloned sequence from the Name list (it should have + sign appended to it).
    Change the 'Start Frame' number to the timeline frame number you'd like it to commence playback from.
    Open the surface editor and select your object's surface name that will host the image sequences.
    If you're using pre LW2018 then open its colour channel's Texture Editor (the T button) and add an Image Map layer ( Add Layer>Image Map ). You should see two layer's in the list. Select one and add the first image sequence to that layer.
    Open that layer's 'Layer Opacity' envelope setting to enter the Graph Editor for it's channel, then set a key frame for when you want the image sequence to finish playing and give it a value of 0 to turn off it's opacity.
    Then change the 'Incoming Curve' to 'Stepped'.
    Return to the Texture Editor and select the Cloned layer from the Layer Name list.
    Set it's image map to the cloned image sequence from the 'Image' drop down list.
    Play it back and viola. That should be that.
    With this technique you can effectively have a pseudo video editor from within the Image Editor. No extra geometry needed. Everything's just tied to your object's surface. Nice and tidy.
    Let us know how it works out for you.
