Thread: Python city block instance off y=0?
    I'm trying to use the python city block object instancing for the first time. I have a scene set up and need some buildings around the periphery for background. Due to the camera angle, I need to set up the instances below the y axis and offset on the x axis, but I can't get that to work properly. I've tried saving the object off center as well as playing with the vertical spacing in the plugin, but I can't get reliable or predictable results. Does it only work with the object centered at 0,0,0?
    Erich
    Jan 2005
    Colorado Springs
    1,792
    Yes, the "base" object should be at (0,0,0), although to place an instanced building above ground, I'd expect the geometry to have its ground-level base or foundation at Y=0 rather than being centered on Y. When placing buildings on rough ground, I always have a story or two of concrete foundation in negative Y so if the center of the building is on sloping ground, the foundation shows on the lower portions of the ground.
    You can use a node network to place the individual instances where you'd like. I've attached a sample LW2019 scene which uses the Distance from the original Base Object to place the Instances in -Y, creating a "hill top" top of setup:
ID:	145213 Click image for larger version.
ID:	145215 Click image for larger version.
    MOV File: Instancer_NegativeYOffset_DistanceToObject_RandomInstanceAttributes_small.MOV
    The Instancer node setup uses the Instance's Fixed Random to rotate each instance by a multiple of 90 degrees (pi/2 radians) and to scale it randomly:
    There's a separate node setup on the Building Fascade surface to give each instance a random color (based upon a Gradient) and random roughness:
    Hope it helps!
    mTp
    Wow, thanks very much for all that!
    Erich
