Thread: Opening 2015 objects in 2018 problems. Please help!
Hybrid View
    Jan 2011
    Kingsport
    22
    I am opening my 2015 objects in 2018. The objects open fine but the textures and shading is blown out as if specular was turned up to a 1000% I have tried to lower the specular value in the standard shader as well as the principled BFDF but it is still shiny. The procedural textures even look different. Is there a problem with opening older models in 2018 or above or is there an easy way to make my models look the same as the 2015 models.
    Use the Convert to Principled command by right clicking on your surface name.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Nov 2003
    jersey
    5,763
    You wont get things looking the same because the rendering systems are quite different... though you can get quite close.
    This'll guide you through some of the basics, including some examples of bringing in and altering pre 2018 stuff...
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Jan 2011
    Kingsport
    22
    Thank you all! This really helps. Is there a good way to get rid of the fireflies in shiny or metallic materials.
