Page 1 of 5 123 ... LastLast
Results 1 to 15 of 61
Thread: Lightning Effects How to in Lightwave ?
    Registered User 3dhotshot's Avatar
    Mar 2009
    Durban
    260
    If anybody knows how to ?
    Near Beaverton, OR
    1,277
    With the new Primitive Lights, I'd think it would be pretty straight forward. Any number of ways to model the "bolts", but they could also be animated. Check out the Primitive_Lights-Neon_Sign.lws scene that was in the Content files.
    Jan 2005
    Colorado Springs
    1,784
    Here's an old thread on creating Lightning:
    https://forums.newtek.com/showthread...o-Vertilectric
    including a pointer to an old William Vaughan video which uses 2-point polygons:
    ftp://ftp.newtek.com/pub/LightWave/T...lectric_CD.mov
    and a pre-LW2018 technique I used using the EdgeTransparency shader (no longer available):
    https://forums.newtek.com/showthread...=1#post1494799
    mTp
    didn't fine tune this technique, but perhaps try...
    Mar 2009
    Durban
    260
    yes erikals i did think of this method nice thx i will try it
    glad to help
    please share the result if it works out
    Feb 2012
    Austin, TX, United States
    160
    oh, you are giving me some good ideas here, guys. I was bummed out we no longer have the Vertilectric? plugin from long ago. And I've been trying to figure out a good workflow for electric arcs w/ some animating ability. I almost thought we as a community might want to delve into re-creating that old plugin (if it would be worth it to anyone) as a python plugin or if we had an adventurous programmer amongst us. But, I think I might be able to do it now after having a brain moment of putting two things together. I'll try this brain child out this evening.
    It's better to have tried and failed, than to have failed to try.
    Patreon - www.patreon.com/ernesttx
    Registered User Oldcode's Avatar
    Jan 2004
    Boston
    395
    Here's a simple lighting object and setup file based on a series of points and lines, with a null object attached to a displacement map. Just move the null back and forth and watch the arc jump. Set luminosity way up and color to preference.
    Lightning.zip
    Good Luck
    Feb 2012
    160
    Got some good results. Still need a few things lined out for steaks.Click image for larger version.
    Angry Mac User Otterman's Avatar
    May 2006
    England
    867
    Why make life difficult, AE is the best tool for the job.
    https://www.videocopilot.net/tutoria...d_electric_fx/
    Feb 2012
    160
    Haha why make life easy. Whatever happened to exploring, experimenting, sense of adventure, doing the impossible, or just plain fun. I like kicking the tires every once in awhile. Besides, I don't have, nor will have, AE.
    Feb 2012
    160
    Getting closer to what I want. Fully controllable with start, middle and end nulls. Growing bolt w/ Fertilizer. Now need to work on branches of lightning.
    Oh duh. Instance Array
    Feb 2012
    160
    Ok so, I had more fun creating electric arc blasts haha
    https://youtu.be/AZFQyWiSNcs
    nice effect, were the light streaks made in LightWave ?
