Thread: Custom for Panel
    Apr 2015
    France
    174
    Custom for Panel
    Is it possible to make a custom for icon and image in Panel or Xpanel?
    creacon
    Nov 2005
    Belgium
    1,304
    Do you mean if you can integrate an image in the panel or in the title bar?
    If you want to put an image in a panel you need to look at the "canvasl" control.
    creacon
    8,152
    If you want to custom draw directly to panel you can use:
    PAN_USERDRAW
    Your panel draw callback.
    Code:
       typedef struct st_LWPanelFuncs {
          DrawFuncs   *drawFuncs;
       } LWPanelFuncs;
    Code:
       typedef struct st_DrawFuncs {
          void (*drawPixel)   (LWPanelID, int color, int x, int y);
          void (*drawRGBPixel)(LWPanelID, int r, int g, int b, int x, int y);
          void (*drawLine)    (LWPanelID, int color, int x1, int y1, int x2,
                                 int y2);
          void (*drawBox)     (LWPanelID, int color, int x, int y, int w,
                                 int h);
          void (*drawRGBBox)  (LWPanelID, int r, int g, int b, int x, int y,
                                 int w, int h);
          void (*drawBorder)  (LWPanelID, int indent, int x, int y, int w,
                                 int h);
          int  (*textWidth)   (LWPanelID, char *text);
          void (*drawText)    (LWPanelID, char *text, int color, int x,
                                 int y);
          const LWDisplayMetrics *(*dispMetrics)();
       } DrawFuncs;
    c = CANVAS_CTL( pf, pan, label, w, h )
    A bordered rectangle for convenient drawing. The width and height don't include the border, so the rectangle (0, 0, w-1, h-1) (relative to the control's HOTX and HOTY) lies inside the border.
    Read docs
    LWSDK/html/globals/panel.html
    search for keyword: draw
    also you can make OpenGL control with:
    c = OPENGL_CTL( pf, pan, label, width, height )
    This creates and initializes an OpenGL window. LWPanels takes care of the platform specific setup for the window. You can draw in this window using standard OpenGL function calls during your event and draw callbacks for the control.
    Apr 2015
    France
    174
    Thanks all for your help.
