Thread: Streaming list disappear tc1
    May 2019
    Lima
    2
    Hi, i have a issue with the streaming list in TC1 console. The list disappears and if I want to create a new output by RTMP for youtube or rtmps for faceebook the customize option also disappears. This happened since March but it was not usual. Since the May update the problem has grown making it impossible to stream
    I have already restored the system twice with the last update and the problem persists
    Please I need to find the solution to this problem. Thanks
    I had this issue once on a mini. This happened after a client deleted all entries from the list and tried to add just one. A restore and not deleting the basic presets solved it. As you can checkmark only the needed entries, there is no problem if you have some entries that you do not use in the list.
    May 2019
    Lima
    2
    Thanks mzafrany but in this case I restored it twice and the list still does not appear. CUSTOM option disappears in "new presets". This happens in a session already created and in a new session
