Thread: UV product label mapping
    Registered User Captain Chaos's Avatar
    Oct 2006
    Philadelphia
    154
    I've done a few tutorials on UV mapping and while it works, I'm getting a lot of distortion on the flat art. Is there a tutorial that's more focused on what I'm doing?
Name:	Screen Shot 2019-05-29 at 10.25.43 AM.png
    Nov 2003
    jersey
    5,792
    Not really there won't be, Id expect... it's too specific a case. That said, its just a case of dragging points around in the UV space to map to the object.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Oct 2006
    Philadelphia
    154
    Ugh. I've been doing that for the better part of the day and it still looks like crap.
    England
    6,018
    UV Mapping is generally tough, distortion free UV mapping for packaging can be really really tough.
    Some starting points I guess could be:
    Try using the PLG UV tools which you can get for free https://www.lightwave3d.com/assets/p...try/plg-tools/
    They seem daunting at first, but if you mark a seam, and then unwrap it will probably give you a decent starting point.
    Also, make sure your UV's are set to subpatch mode in the vertex maps panel, you can switch between the types of UV-ing modes.
    If you're really struggling, you could try sharing the model and seeing if someone can do a better job. It's just one of those things that can be quite difficult, but once you've gone through the pain and torture, it can become easier. Packaging though, like this, can be pretty tricky, especially when you need logos to not be distorted etc.
    Desk Work:
    Desk Home:
    You've got some pinching in your geo at the bottom and some weird stuff at the top. It looks like you have separated your UV's and surfaces out as front-back-left side-right side, that may also be causing some issues but UVing as one big UV can be tricky too in this case. If you are separating out your sides and front/back, can't you just planar map the textures?
    8,149
    Quote Originally Posted by Captain Chaos View Post
    Did you try UV mapping with Morph Vertex Map trick?
