Thread: TC 8000 remote power switch?
    Oct 2017
    Norway
    30
    We are in the process of moving our Tricaster 8000 to a server room that we won't have access to all the time. We don't want to leave the Tricaster running all the time, so we need a way to access the power switch remotely. Are there any good options for this?
    The rooms are only about 10m apart and we can run cables between them. There is also plenty of ethernet running between the rooms.
    Thanks!
    Jun 2012
    Australia
    267
    Depending on the BIOS you may find your unit has an option for what to do on power restore (always on, always off, or last power state). If so you might do well to set it to 'always on' and then install an IP controllable power point (eg; https://sonoff.itead.cc/en/).
    May 2017
    Windsor, Ontario
    7
    Quote Originally Posted by AndersM View Post
    Thanks!
    I take it your control surface is USB due to it being on a TC8000. What did you do to extend that as well as keyboard and mouse to another room? I'd like to do the same but the move would only displace the TriCaster by about 15 to 20 feet of cable length. Are you extending via usb to ethernet adaptor?
