Results 1 to 9 of 9
Thread: LightWave Configs.
    Murcia, Spain
    3,004
    LightWave Configs.
    Wonder if anyone can help me.
    Where does LW store its configs. I know the usual place in the .NewTek folder, however i uninstalled and deleted all files and folders and reinstalled LW, but it still sees the plugin configs from the previous installation. Is there somewhere else like ProgramFiles, Common or AppData where they are also stored.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    ack ack Markc's Avatar
    Feb 2006
    England
    1,354
    Best way is to point at specific configs, create a Preferences file within the LW installed folder (in applications/programs). If you check this folder after you close LW the configs should be there.
    Mac Pro (2010) OSX 10.13 RX580 Pulse LW2019
    Murcia, Spain
    3,004
    Thats what i did, i always use custom configs and places. Im just wondering if LW when installing also puts copies somewhere else as backup. I notice now it keep backups called .Bak in the configs folder.
    Just cant understand why if i have completely uninstalled LW and all of its stuff it still see what plugins and such i had before.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Feb 2006
    England
    1,354
    Actually your right, I know when I install new LW versions, I copy my plugins from previous version and all my commercial plugins are activated.
    So there is something somewhere on my system stored with my plugin license info.
    Are you having trouble with a particular plugin?
    Murcia, Spain
    3,004
    Oh no not plugin issues per say. I keep seeing multiple versions of the same plugin when i try to edit my menus. Ive checked and i dont have multiple versions of the same plugin. Ive cleaned the configs out, re run and re scanned my plugins and still the menu lists 2/3/4 or sometimes more versions of the same plugin.[
    ATTACH=CONFIG]145081[/ATTACH]Click image for larger version.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Near Beaverton, OR
    1,345
    Hey JohnMarchant,
    Just curious why you aren't using the OD Tools since I know you have them, other than simply not knowing they exist?
    OD_Configs
    https://origamidigital.com/dokuwiki/...ols:od_configs
    OD_MODConfigs
    https://origamidigital.com/dokuwiki/...:od_modconfigs
    Murcia, Spain
    3,004
    Hi, Yes i have them and do use them. This seems to be a thing when you first install, to be honest it almost feels like every time you do a rescan when you open the menu editor it is like its added another heading for the plugin. Ive checked all my third party plugins and there are no copies or double entries, it only seems to happen to some.
    Its not a big deal at all and not a show stopper, i was more interested in an answer as to whether LW when installed puts any backups in the AppData, Common or some other directory that i am not aware of.
    I have just restarted LW with totally clean configs and rescanned my third party plugins and now when i check my menu layouts they are there again. Im also wondering if its the plugin/script itself as it only happens too about 6 plugins and the same ones all the time.
    EDIT, Well look what i found in a Temp Folder on C Drive, as you can see from my hub nothing is pointing there for configs and yet this file in the temp folder/lwhub was updated only yesterday.
Name:	Temp Folder.jpg
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Near Beaverton, OR
    1,345
    Quote Originally Posted by JohnMarchant View Post
    Sneeky little sucker.
    Murcia, Spain
    3,004
    I have no problem with it doing that i just want to know where it puts stuff in case i need to uninstall and clean out.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
